[Qgis-developer] Large scale and rounding issues
    Marco Hugentobler
    marco.hugentobler at sourcepole.ch
    Sun May 25 23:59:57 PDT 2014
Hi Leyan
QgsGeometry::lineContainedInLine and QgsGeometry::pointContainedInLine
are two other places using tolerances that might be a problem at large
scales.
Sounds resonable to me to restrict the zoom level at a point where it
cannot be supported anymore. Don't know if there is any application out
there using scales beyond 1000:1.
Regards,
Marco
On 25.05.2014 05:38, Leyan wrote:
> Hi devs,
> QGis allows quite a lot of zooming in: it is easy by playing with the
> mouse wheel to go to scales like 3,000,000:1. However, this does not
> mean QGis actually support them and different features will start to
> fail at different zoom level, some of them quite early. For example,
> labelling will fail around 1:1 in some cases (linked to geographic
> coordinate systems?). Node edition, snapping also fail quite early.
> Later, display starts to become erratic, with some lines or nodes
> disappearing randomly.
> For example, http://hub.qgis.org/issues/10234 is a user doing some
> large scale mapping of a building in WGS84 (maybe not ideal, but in
> theory supported by QGis). He has some issues to select nodes for
> edition.
> I looked in the code and found a culprit on qgsvectorlayer.cpp line
> 2451 : there is a epsilon defined as "crs().geographicFlag() ? 1e-12 :
> 1e-8" , but this epsilon is later compared to the square of the
> distance, and the distance considered zero if smaller. This means that
> all distances below 1e-6 degree, which is around 10 cm, will be
> considered zero, which prevents selecting the correct node or segment.
> Of course, this is not an issue for most use cases, but this can
> affect some legitimate use.
> More important, the limits are not consistant and there is no
> guarantee for the user about which feature will be available or not at
> which level of precision.
> I would like to restrict more strictly the zoom level (something like
> 1000:1?), but ensure all features work as expected at these zoom
> levels (or maybe make two categories of zoom, a "normal" one where
> everything works and an "extended" one with no guarantee). Then the
> DEFAULT_SEGMENT_EPSILON and other constants can be derived for both
> geographic and projected coordinate systems.
> What do you think ?
> Leyan
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
