[Qgis-developer] [Qgis-user] [Plugin presentation] LayerBender
Alex Mandel
tech_dev at wildintellect.com
Tue May 27 08:44:39 PDT 2014
Might also want to merge in the
https://plugins.qgis.org/plugins/qgsAffine/ which provides direct user
control over an affine transformation. Possibly as an alternate middle
step or a way to save the transformation parameters in case you want to
apply them in batch.
I was also thinking about filing a ticket to ask for vector to be added
to the core Georeferencer, since gdal 1.10 ogr2ogr can take a gcp list
and apply polynomial 1,2 or 3 to a vector and reproject it. So after the
previous mentioned mergers it would be good to see how the core
georeferencing tool could be enhanced by these slightly different
workflows and be allowed to do either vector or raster.
Thanks,
Alex
On 05/27/2014 12:03 AM, G. Allegri wrote:
> AFAIK vectGeoRef does an affine transformation.
> It would be great if the two tools would merge into a single plugin,
> bringing thir different solutions.
> giovanni
> Il 27/mag/2014 08:55 "Tim Sutton" <lists at linfiniti.com> ha scritto:
>> Hi
>> On Mon, May 26, 2014 at 9:18 PM, Olivier Dalang <olivier.dalang at gmail.com>wrote:
>>> Dear lists,
>>> I'm happy to present my new plugin called "LayerBender".
>>> It's purpose is to allow to align/distort vector layers to match a
>>> source, very much like georefencer does for raster. It seems ArcGIS and
>>> OpenJump call this feature "Rubber sheeting".
>>> Demonstration video : https://vimeo.com/96142479
>>> I needed this in a project I'm working on to align some already digitized
>>> historical maps.
>>> Please note that the plugin is still experimental and not much tested yet
>>> (and only under windows)... So please be understanding in case of problems !
>>> All feedback is welcome, either here or on
>>> https://github.com/olivierdalang/VectorBender
>>> Hope you like it !
>> Wow thats awesome man - thanks for sharing!
>> Regards
>> Tim
>>> Best,
>>> Olivier
