[Qgis-developer] Make error - QGIS Latest (2.6.0)
Jürgen E. Fischer
jef at norbit.de
Sat Nov 1 01:09:53 PDT 2014
Hi Mark,
On Sat, 01. Nov 2014 at 16:07:57 +1030, Mark Wynter wrote:
> I'm getting the following error with QGIS 2.6.0 latest. I'm running
> CentOS65 however earlier today I successfully installed QGIS2.4.0 on the same
> machine using the exact same steps.
> And this is the error I get:
> [ 31%] Building CXX object src/gui/CMakeFiles/qgis_gui.dir/qgscodeeditor.cpp.o
> /root/qgis-2.6.0/src/gui/qgscodeeditor.cpp: In member function \u2018void QgsCodeEditor::insertText(QString)\u2019:
> /root/qgis-2.6.0/src/gui/qgscodeeditor.cpp:114:34: error: \u2018replaceSelectedText\u2019 was not declared in this scope
> make[2]: *** [src/gui/CMakeFiles/qgis_gui.dir/qgscodeeditor.cpp.o] Error 1
> make[1]: *** [src/gui/CMakeFiles/qgis_gui.dir/all] Error 2
> make: *** [all] Error 2
Hm, which version of QScintilla2 are you using? Something earlier than v2.5
from 29th March 2011? Because that's where replaceSelectedText() was added to
QsciScintilla.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141101/5eff6b5d/attachment.pgp>
