[Qgis-developer] Raise minimum CMake version to 2.8.6
Jürgen E. Fischer
jef at norbit.de
Mon Nov 3 03:04:17 PST 2014
Hi Matthias,
On Mon, 03. Nov 2014 at 11:48:52 +0100, Matthias Kuhn wrote:
> As we are out of feature freeze I was thinking of merging the
> possibilities to compile against Qt5. One of the difficulties was to
> have the possibility to compile the test suite. It is possible to have
> the test suite compile against both versions - Qt4 and Qt5 - by using
> automoc. Automoc is only available starting from CMake 2.8.6. Is there
> any objection against raising the minimum version of CMake?
Not from me. Even Ubuntu precise is at 2.8.7.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141103/31c8a0fb/attachment-0001.pgp>
