[Qgis-developer] Trouble with PostGis
Vincent Picavet vincent.ml at oslandia.com
Wed Nov 5 01:18:44 PST 2014
Hi Walter,
Note that if you want to troubleshoot PostGIS problems, you should look at the
postgres side, not the QGIS one. It would have taken 10 minutes to get the
problem here.
So :
* configure PostgreSQL server to output logs for every query
* rerun these queries with EXPLAIN in pgadmin / psql
* Use something like pgBadger to analyze your logs and find the bad queries
There are a lot of other PostgreSQL-related tools which can be useful for
auditing, fine-tuning, troubleshooting PostgreSQL, but it is a bit off-scope for
this list.
Vincent
Le mardi 4 novembre 2014 22:38:04, walter.nordmann a écrit :
> may be i got it. after purging and recreating idx_planet_boundary and
> idx_planet_admin_level the cursor-query is using those indices and
> performance is on.
> yes, i'm running vacuum analyze on a regular base and the last run was this
> morning.
> if the performance is going down again, i'll contact the postgres people.
> Thanks
> walter
> http://osgeo-org.1560.x6.nabble.com/Trouble-with-PostGis-plugin-tp5166669p
> 5171236.html Sent from the Quantum GIS - Developer mailing list archive at
> Nabble.com. _______________________________________________
> Qgis-developer mailing list
