[Qgis-developer] [Issue] Filter Legend By Map Content doesn't maintain point displacement legend
René-Luc Dhont
rldhont at gmail.com
Wed Nov 5 07:19:25 PST 2014
Hi Martin,
I've opened an issue :
http://hub.qgis.org/issues/11572
And proposed a patch :
https://github.com/qgis/QGIS/pull/1673
Thanks to review and backport it.
Regards,
René-Luc
Le 05/11/2014 14:36, René-Luc Dhont a écrit :
> Hi dev,
> I found a bug in 'Filter Legend By Map Content'. For point vector
> layer render with 'displacement point', when 'Filter Legend By Map
> Content' is activated, the legend is not rendered even if it has to be.
> I'd like to correct it. Where the 'Filter Legend By Map Content' is
> done ?
> I think it's due to the style definition. Is someone known which file
> is responsible ?
> Regards,
> René-Luc
