[Qgis-developer] transition to QT5... QT4 removed will be removed from Debian Jessie
Richard Duivenvoorde
rdmailings at duif.net
Fri Nov 7 00:13:58 PST 2014
On 06-11-14 10:41, Matthias Kuhn wrote:
> On 06.11.2014 10:33, Matthias Kuhn wrote:
>>> could the migration have an impact on plugins?
>> Yes, some classes are no longer supported but the delta is small
> The biggest problem will probably be old-style signal/slot connections.
> Maybe we should encourage people to use new-style connections to be
> prepared.
This, and an easy way to install a QT5-QGIS version, so plugin devs who
are not able to compile can 'just install QT5-QGIS and just test their
plugin?
Regards,
Richard
