[Qgis-developer] Field Calculator "permanence"
Zoltan Szecsei
zoltans at geograph.co.za
Fri Nov 7 08:32:26 PST 2014
Hi Andreas,
I'll fiddle with the Postgis idea - thanks.
The orange part below:
I closed the shapefile, deleted from legend and re-opened it - but could
not see my virtual field, nor the expression I used to create it.
Have I missed a trick somewhere?
Regards,
Z
On 2014/11/07 18:25, Andreas Neumann wrote:
> Hi,
> What you probably ask for are database triggers combined with storage.
> This is not what virtual fields are for. If they were stored - they
> wouldn't be called virtual ;-)
> You can do that f.e. with Postgis. With shapefiles not. However, if
> you share the project with the other PC, the virtual fields work fine.
> Andreas
> On 07.11.2014 17:21, Zoltan Szecsei wrote:
>> Hi Matthias,
>> Thanks for the quick answer.
>> The virtual field acts just like I want it to, except that it does
>> not permanently store the column in the attribute table.
>> I tried getting clever by then adding a second 'Field Calculation' to
>> update the existing 'Sheet' field from the virtual field, but that
>> won't do it either.
>> So, for me there are two shortcomings:
>> 1. To be able to store and recall the 'Expression' and not lose it
>> after closing the Field Calculator
>> 2. To be able to add the virtual fields that you create, into the
>> attribute table.
>> 3. (And then of course to re-open the Shape file on another PC and
>> have these Field Calculations still functional)
>> Any further possibilities I can try?
>> Regards & thanks again,
>> Zoltan
>> On 2014/11/07 18:01, Matthias Kuhn wrote:
>>> Hi Zoltan,
>>> Since QGIS 2.6 this possibility exists. It is called "Virtual Field".
>>> You must not create the attribute when creating the shapefile. Just open
>>> the field calculator, create a new field in there and check the "virtual
>>> field" checkbox.
>>> Regards,
>>> Matthias
>>> On 07.11.2014 16:54, Zoltan Szecsei wrote:
>>>> Hi,
>>>> I'm using QGIS 2.6.0 on Win 7 x64 - installed via OSGEO4w
>>>> Is there a way to store your field calculator expression to always
>>>> process and update that specific field, should geometry be edited or
>>>> created for that Layer?
>>>> Let's say I want to create a blank POINT shape file, with a text
>>>> attribute called "Sheet".
>>>> Whenever a POINT is created or moved, I want this field to be
>>>> dynamically updated with:
>>>> tostring(abs(toint($y)))+tostring(abs(toint($x)))
>>>> For testing thus far have:
>>>> * created 2 points
>>>> * Opened the field calculator, clicked 'Update Existing Field' and
>>>> put in the expression.
>>>> * The two existing points now have the correct TEXT values in the
>>>> Sheet field
>>>> * I close the Field calculator
>>>> * Create a new point in my layer
>>>> * open the attribute table to find that the 'Sheet' field for this
>>>> new point is blank
>>>> * I open the Field Calculator and I cannot even find a way to call
>>>> back the previous expression I used.
>>>> Am I using the correct QGIS functionality to achieve what I need to,
>>>> and if so, where am I going wrong?
>>>> Thanks & regards,
>>>> Zoltan
>>>> Zoltan Szecsei PrGISc [PGP0031]
>>>> Geograph (Pty) Ltd.
>>>> GIS and Photogrammetric Services
>>>> P.O. Box 7, Muizenberg 7950, South Africa.
>>>> Mobile: +27-83-6004028
>>>> Fax: +27-86-6115323www.geograph.co.za
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Geograph (Pty) Ltd.
Geograph (Pty) Ltd.
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141107/d70af8a5/attachment.html>
