[Qgis-developer] Python tests and C++ tests for the same functionality
Nathan Woodrow
madmanwoo at gmail.com
Sat Nov 8 07:00:18 PST 2014
Vote for 2. Python is a lot easier to test in, and no building step.
On Sat, Nov 8, 2014, 11:30 PM Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Hi,
> While working on the test suite and trying to get all tests to pass I
> realized that there are a lot of tests that exist in two versions: C++
> and python (e.g. composerhtml, atlas composition). The problem with that
> is, that they work on the same set of reference images and either one or
> the other fails because of slight inconsistencies in the result (nothing
> we should worry about, see e.g. [1]). I don't know exactly, what the
> source of these is, I assume that either there are some
> rounding/floating point differences in the python API or that meanwhile
> one or the other test was modified but not both synchroneously.
> What can we do?
> (1) We could accept these deviations with anomalies or multiple
> reference images.
> (2) Or we could remove the C++ test in favor of the python test which
> will test the same functionality/codepath and the python binding in
> addition. That would have the advantage that maintainability will be
> easier, because not every of these tests needs to be written and
> adjusted twice. The only disatvantage I can see is that you then don't
> know if it's the python binding or the logic behind it that made a test
> fail. But that shouldn't make a big difference in the time one needs to
> debug a test.
> My favorite is (2).
> Are there any thoughts from other devs/authors of these tests?
> Best
> Matthias
> [1] http://dash.orfeo-toolbox.org/testDetails.php?test=26809858&
> build=162985
> Help getting QGIS to the next level of quality before November 15!
> http://blog.vitu.ch/10102014-1046/crowdfunding-initiative-
> automated-testing
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141108/ef99ceac/attachment.html>
