[Qgis-developer] QGIS-Server Coredump printing with lizmap webclient
Roy royroge at outlook.com
Mon Nov 10 03:22:31 PST 2014
Il 10/11/2014 11.44, Alessandro Pasotti ha scritto:
> 2014-11-10 11:40 GMT+01:00 Roy <royroge at outlook.com>:
>> Dear all,
>> i'm testing qgis-server 2.6.0 with "lizmap web client" on ubuntu 12.04
>> server
>> and qgis server crashes trying to print a vector layer with "advanced
>> symbols"
>> ( "line pattern fil"l and "marker line"); apache log following:
>> # apache2 error.log ########
>> #mod_fcgid: error reading data, FastCGI server closed connection
>> #[Mon Nov 10 11:28:47 2014] [error] [client 127.0.0.1] Premature end of
>> script headers: qgis_mapserv.fcgi
>> #[Mon Nov 10 11:28:51 2014] [error] mod_fcgid: process
>> /usr/lib/cgi-bin/qgis_mapserv.fcgi(1998) exit(communication error), get
>> signal #11, possible coredump generated
>> # apache2 error.log END ########
>> using more simple (simple fill) symbology this does not appens
>> is this possibly a bug or are we not supposed to use "fancy" symbols printig
>> with qgis-server ...
>> thanks,
>> Roy.
>> P.S.  is this the right list to ask questions about lizmap and qgis-server?
> See if this is your case:
> http://hub.qgis.org/issues/9763
> More info here:
> http://www.itopen.it/2014/03/13/qgis-server-setup-notes/
> In short: make sure you have an (fake) X sever running.
Thank you Alessandro that's working !
regards,
Roy.
