[Qgis-developer] Improving the legend for map-units, data-defined symbology, diagrams and labels
Roy
royroge at outlook.com
Fri Nov 14 00:06:59 PST 2014
Il 14/11/2014 00.22, Andreas Neumann ha scritto:
> But I think we need to be able to restrict legends where map units
> are involved to a certain min/max scale range. So the symbols don't
> get too big or too small and get into each others way.
But in this way you'll have a legend not representing the symbology that
is represented in the map and i think this would be an error;
using map units you can however restrict the layer visibility according
to the nominal scale of your data (or min/max scale).
my 2c, Roy.
