[Qgis-developer] Write custom c++ application using QGIS under windows
Gary Sherman
gsherman at geoapt.com
Mon Nov 17 11:50:10 PST 2014
On 11/17/14 9:50 AM, eliu1234 wrote:
> Anyone was able to write qgis c++ application under Windows?
> The problem that I am encountering is that header files such as
> "<"qgsapplication.h">" cannot be found. I have installed qgis 2.6 and those
> files actually do not exist.
> What do I need to do in order to find these header files so I can do C++
> programming under windows?
> My .pro file can be found at the following stackoverflow post:
> http://stackoverflow.com/questions/26920574/cannot-find-qgsapplication-h-and-other-header-files
You need to install the QGIS source in order to get the header files.
See the "SOURCES" tab on http://qgis.org/en/site/forusers/download.html
for how to get it.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Write-custom-c-application-using-QGIS-under-windows-tp5173377.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Gary Sherman
Founder, QGIS Project
Consulting: geoapt.com
Publishing: locatepress.com
We work virtually anywhere
