[Qgis-developer] Problems with developing custom c++ qgis application with QtCreator and MSVC2008 on Windows
eliu1234
lby20102 at hotmail.com
Mon Nov 24 08:17:59 PST 2014
QgisInterface is an abstract class. How are you initializing it? Or do you
just declare it and add a raster layer directly? Because from that link, I
see the addRasterLayer method is a pure virtual function.
Nejia wrote
> QgisInterface *m_ptInterface;
> See
> http://qgis.org/api/2.6/classQgisInterface.html#a808a34b507a8c4204d607a5857d62748
> Regards,
> Nejia
> -----Message d'origine-----
> De :
> qgis-developer-bounces at .osgeo
> [mailto:
> ] De la part de eliu1234
> Envoyé : vendredi 21 novembre 2014 21:36
> À :
> qgis-developer at .osgeo
> Objet : Re: [Qgis-developer] Problems with developing custom c++ qgis
> What is the m_ptInterface in your code?
> Nejia wrote
>> I use the same environment of Qgis to write c++ plugins:
>> http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/
>> doc/INSTALL.html#toc14
>> to add raster layer:
>> m_ptInterface->addRasterLayer("http://server.arcgisonline.com/ArcGIS/r
>> est/services/World_Imagery/MapServer?f=json&pretty=true","raster");
>> Regards,
>> Nejia
>> De :
>> [mailto:
>> Envoyé : jeudi 20 novembre 2014 21:40
>> À :
>> Do you have a system setup that can write qgis c++ application? If you
>> do, can you create a valid raster layer from that?
>> Nejia wrote
>>> 1- see my response here
>>> http://stackoverflow.com/questions/26920574/cannot-find-qgsapplicatio
>>> n
>>> -h-and
>>> -other-header-files/27035138#27035138
>>> De :
>>> [mailto:
>>> Envoyé : mercredi 19 novembre 2014 17:39 À :
>>> 1. So in the .proj file, what do i need to change?
>>> 2. My Python works in this case, it is the C++ part that is not working.
>>> Nejia wrote
>>>> Hi,
>>>> 1- QGIS and Qt libraries shipped with Osgeo4W are compiled using
>>>> release mode so if you want to debug your application you can use
>>>> RelWithDebInfo mode.
>>>> 2- see:
>>>> http://gis.stackexchange.com/questions/120823/how-to-load-a-wms-laye
>>>> r
>>>> using-
>>>> pyqgis
>>>> http://ieqgis.wordpress.com/2014/08/09/adding-esris-online-world-ima
>>>> g
>>>> e
>>>> ry-dat
>>>> aset-to-qgis/
>>>> Cheers
>>>> Nejia
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/Problems-with-developing-custom-c
>>> qgis-a
>>> pplication-with-QtCreator-and-MSVC2008-on-Windows-tp5173711p5173838.h
>>> t ml Sent from the Quantum GIS - Developer mailing list archive at
>>> Nabble.com.
>>> Qgis-developer mailing list
>>> Qgis-developer at .osgeo
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> http://osgeo-org.1560.x6.nabble.com/Problems-with-developing-custom-c-
>> qgis-application-with-QtCreator-and-MSVC2008-on-Windows-tp5173711p5174
>> 130.html Sent from the Quantum GIS - Developer mailing list archive at
>> Nabble.com.
> http://osgeo-org.1560.x6.nabble.com/Problems-with-developing-custom-c-qgis-application-with-QtCreator-and-MSVC2008-on-Windows-tp5173711p5174285.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-developing-custom-c-qgis-application-with-QtCreator-and-MSVC2008-on-Windows-tp5173711p5174568.html
