[Qgis-developer] QGIS custom widgets with python plugins
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Nov 25 00:35:16 PST 2014
Hi Stefan,
To properly compile the UI file using pyuic4, you need to have the uic
widget plugin installed.
This is the file qgis_customwidgets.py that should be located in
/usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/
This file can be either installed by the package python-qgis-common or
using -WITH_CUSTOM_WIDGETS=TRUE if you compile your own QGIS (I suppose
this requires a make install).
Let me know if this helps.
Best wishes,
Denis
On 14.11.2014 16:13, Ziegler Stefan wrote:
> Hi
> I sucessfully used QGIS custom widgets (eg. qgscollapsiblegroupbox) in qt designer in and then with python plugins with "uic.loadUiType()". Using the "traditional" pyuic approach I get an missing module error when starting QGIS:
> ImportError: No module named qgscollapsiblegroupbox
> I'm on Ubuntu 14.04 with an own compiled QGIS master. Do I have to put "libqgis_customwidgets.so.2.7.0" somewhere specific? Or is there anything else I have to do?
> Regards
> Stefan
> Freundliche Grüsse
> Stefan Ziegler
> Kantonsgeometer
> Amt für Geoinformation
> Amtliche Vermessung
> Rötistrasse 4
> 4500 Solothurn
> Telefon +41 32 627 75 96
> Telefax +41 32 627 75 98
> stefan.ziegler at bd.so.ch
> http://www.so.ch
> Qgis-developer mailing list
