[Qgis-developer] Core Python plugins and their dependencies
Tom Kralidis
tomkralidis at gmail.com
Tue Nov 25 06:14:05 PST 2014
On Tue, 25 Nov 2014, Jürgen E. wrote:
> Date: Tue, 25 Nov 2014 14:45:55 +0100
> From: Jürgen E. <jef at norbit.de>
> Reply-To: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Core Python plugins and their dependencies
> Hi Alex,
> On Tue, 25. Nov 2014 at 15:06:30 +0200, Alexander Bruy wrote:
>> DB Manager depends on psycopg2 and pyspatialite, but we does not ship this
>> packages into QGIS source tree. Same for Processing, it contains several
>> algorithms that require matplotlib and we does not bundle matplotlib in QGIS
>> source tree. And it is fine, as user can easily install this packages using
>> package manager or pip.
> We ship pyspatialite - that's not available everywhere and in case we're using
> internal spatialite it should be built against that version.
>> I think it would be good to have clear policy on this.
> Well, I don't have a good idea what thise clear policy could be. I'd say there
> should be a compelling reason why third party dependencies are included.
> pyspatialite is there because of internal spatialite. Maybe that can be
> reconsidered too. I doubt that anything uses internal spatialite anymore and
> there also pysqlite that could be used with spatialite instead of pyspatialite.
> owslib is not available everywhere - also AFAIK it's closely releated to
> MetaSearch and has the same upstream.
> Everything else could be removed from ext-libs AFAICS.
FYI the other deps in https://github.com/qgis/QGIS/tree/master/python/ext-libs are either
required by OWSLib or MetaSearch proper.
OWSLib: dateutil, pytz,
jinja2: markupsafe, pygments, six
I've deleted python/ext-libs/tests as this was a (since fixed) buggy artifact of the OWSLib build/install.
