[Qgis-developer] pb with change attribute value in QGIS 2.6
Nejia nejia at spaceyes.fr
Tue Nov 25 07:50:58 PST 2014
I have a tool that allow to edit attribute of features (only one attribute):
1-      I select the feature by click on it: vectorLayer->getFeatures(
QgsFeatureRequest().setFilterRect( tSelectRect ).setFlags(
QgsFeatureRequest::ExactIntersect ))
2-      Modify the attribute
3-      Validate attribute change : vectorLayer->changeAttributeValue(
fId(), iField, newValue,oldValue );
The attribute change in attribute table but not on the label (layer is
labeled with the attribute) and in the identify result dialog.
I compile my plugin with libraries of Qgis 2.6 shipped with OSGeo4W, if I
use libraries of QGIS that I build from sources it work without any problem.
I compiled the same plugin with libraries of QGIS 2.4 shipped with OSGeo4W
and it worked fine.
Regards
Nejia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141125/8bf314cb/attachment.html>
