[Qgis-developer] Core Python plugins and their dependencies
Alexander Bruy
alexander.bruy at gmail.com
Tue Nov 25 08:28:50 PST 2014
Hi Tom,
yes, I know that all this packages required by MetaSearch.
But as Jürgen said all this packages available from package
manager in most Linux distros and in OSGeo4W.
2014-11-25 16:14 GMT+02:00 Tom Kralidis <tomkralidis at gmail.com>:
> On Tue, 25 Nov 2014, Jürgen E. wrote:
>> Date: Tue, 25 Nov 2014 14:45:55 +0100
>> From: Jürgen E. <jef at norbit.de>
>> Reply-To: qgis-developer at lists.osgeo.org
>> Subject: Re: [Qgis-developer] Core Python plugins and their dependencies
>> Hi Alex,
>> On Tue, 25. Nov 2014 at 15:06:30 +0200, Alexander Bruy wrote:
>>> DB Manager depends on psycopg2 and pyspatialite, but we does not ship
>>> this
>>> packages into QGIS source tree. Same for Processing, it contains several
>>> algorithms that require matplotlib and we does not bundle matplotlib in
>>> QGIS
>>> source tree. And it is fine, as user can easily install this packages
>>> using
>>> package manager or pip.
>> We ship pyspatialite - that's not available everywhere and in case we're
>> using
>> internal spatialite it should be built against that version.
>>> I think it would be good to have clear policy on this.
>> Well, I don't have a good idea what thise clear policy could be. I'd say
>> there
>> should be a compelling reason why third party dependencies are included.
>> pyspatialite is there because of internal spatialite. Maybe that can be
>> reconsidered too. I doubt that anything uses internal spatialite anymore
>> and
>> there also pysqlite that could be used with spatialite instead of
>> pyspatialite.
>> owslib is not available everywhere - also AFAIK it's closely releated to
>> MetaSearch and has the same upstream.
>> Everything else could be removed from ext-libs AFAICS.
> FYI the other deps in
> https://github.com/qgis/QGIS/tree/master/python/ext-libs are either
> required by OWSLib or MetaSearch proper.
> OWSLib: dateutil, pytz,
> jinja2: markupsafe, pygments, six
> I've deleted python/ext-libs/tests as this was a (since fixed) buggy
> artifact of the OWSLib build/install.
> Qgis-developer mailing list
Alexander Bruy
