[Qgis-developer] Travis build failed: cannot reproduce
Even Rouault even.rouault at spatialys.com
Thu Nov 27 01:30:50 PST 2014
Le jeudi 27 novembre 2014 10:17:01, vous avez écrit :
> On Thu, Nov 27, 2014 at 08:25:35AM +0100, Alessandro Pasotti wrote:
> > Hi,
> > build fails but I cannot reproduce on my dev machine:
> > https://travis-ci.org/qgis/QGIS/builds/42216306#L907
> > Any hint?
> Maybe a different cmake version ?
> Add a cmake --version in the .travis.yml file to check the online version.
If I may suggest something (not that I'm volunteering to do it myself for QGIS
;-)), a Vagrant setup based on a Ubuntu Precise 64bit might be helpful to have
a reference configuration very close to a Travis VM, so that people can easily
reproduce and debug build or test failures.
An exemple of such a Vagrantfile :
http://svn.osgeo.org/gdal/trunk/gdal/Vagrantfile
And instructions how to use it:
https://trac.osgeo.org/gdal/wiki/Vagrant
Even
http://www.spatialys.com
