[Qgis-developer] Error Saving WFS edits in QGIS 2.4 and 2.5
Scott
sctevl at gmail.com
Wed Oct 1 10:47:48 PDT 2014
Hello,
I'm using QGIS 2.4 and QGIS 2.5 b044d4d on OS-X. I am trying to edit a
point layer that is being served out as WFS 1.3 from GeoServer 2.5. When I
try to edit attributes or the geometry, I get an error that says:
Could not commit changes to <layername> (I tried a couple).
Errors: ERROR: 1 geometries not changed
Provider errors: empty response.
However, I'm able to see that the new edit successfully saved in GeoServer.
If I remove the layer and add it again in QGIS then the update is there.
The WFS I am using works with a mobile app and with OpenLayers 3 so I'm
pretty sure the service is functioning properly.
Any ideas on troubleshooting?
Thanks,
Scott
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141001/6ca41942/attachment.html>
