[Qgis-developer] PostGIS warning details in QGIS master
Pedro Venâncio
pedrongvenancio at gmail.com
Thu Oct 2 16:48:53 PDT 2014
Hi Denis,
I just tested on Linux, with two simple shapefiles (attached), with only
two lines each. Making a copy of the shapefiles, all goes well.
If you import the shapefiles to postgis (with dbmanager) to
multilinestring, they stay with equal pkeys. When I do the copy / paste
(which worked fine with the same data in shapefile format), QGIS shows the
warning message "Paste features: no features could be successfully
pasted.". Running QGIS with GNU gdb, does not appear any error at the time
the warning is shown.
I also tested this with points, multipoints, and Multipolygons, and the
same happens.
The proof that I believe show that the problem is in primary key is:
importing the two layers attached to the postgis with dbmanager, you get
layer_1
id_0* | id | desc
1 | 1 | 1
2 | 2 | 2
layer_2
id_0* | id | desc
1 | 1 | 1
2 | 2 | 2
*pkey
If I delete the second line of layer_2, and copy the second line of layer_1
and paste on layer_2, it already works, and layer_2 becomes:
layer_2
id_0* | id | desc
1 | 1 | 1
3 | 2 | 2
(id_0 is 3 because of the sequence).
The only explanation I find for this behavior is QGIS verify the violation
of unique constraint of pkey field id_0, and launch the warning and prevent
the pasting.
What do you think?
Thanks!
Best regards,
Pedro
2014-10-02 14:42 GMT+01:00 Rouzaud Denis <denis.rouzaud at gmail.com>:
> Hi Pedro,
> As said, copy/paste only tries to convert geometries and will paste if
> possible.
> Foreign key violation is only detected by Postgis, so the reason why QGIS
> is not actually pasting is not due to a FKey violation.
> Do you have a debugging environment or can you provide some demo data?
> Best wishes,
> Denis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141003/52feca7b/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141003/52feca7b/attachment.zip>
