[Qgis-developer] RFC for python server plugins ready for voting
G. Allegri giohappy at gmail.com
Sat Oct 4 16:13:25 PDT 2014
+1 for the observer pattern. Having the ability to install "middlewares"
within the flow would be great. In this case I would suggest to consider
the opportunity to choose the plugin execution order (i.e. plugin1 request
processing should happen before plugin2, etc.).
+0 in case of the 404 method is employed. In this case I prefer to use an
app out of qgis server...
Il 04/ott/2014 14:52 "Alessandro Pasotti" <apasotti at gmail.com> ha scritto:
> 2014-10-04 13:17 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> > The slides dont say nothing about the optionality of this.
> > Should be possible to disable all the python side using some compile
> settings ?
> Of course yes.
> > like
> > "disable-python-server-side" ?
> > Or enable it only for speciic project.
> This could be easily implemented at the webserver level or directly
> inside the plugins in case of need.
> > So avoid to have more insances.
> > Something with python capability and other without python capability ?
> > Aso a last question is the accounting.
> The plugin support has no direct implications with authentication or
> authorization. What the plugins will implement (and how they'll do it)
> is far beyond the scope of my RFC.
> Alessandro Pasotti
> w3:   www.itopen.it
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141005/1cac94b0/attachment.html>
