[Qgis-developer] Render with labels
Geo DrinX geodrinx at gmail.com
Mon Oct 6 02:25:24 PDT 2014
Hello,
Sorry if I repeat my question that I sent some time ago,  but it seems
very relevant
to the topic.
I noticed that using  the    .render()    function  with  pyQgis > 2.2
the labels are not  visible.
This is my test source code (taken from my GEarthView plugin):
                iface = qgis.utils.iface
                mapRenderer = mapCanvas.mapRenderer()
                mapRect = mapRenderer.extent()
                width = mapRenderer.width()
                height = mapRenderer.height()
                srs = mapRenderer.destinationCrs()
                # create output image and initialize it
                image = QImage(QSize(width, height), QImage.Format_ARGB32)
                image.fill(0)
                #adjust map canvas (renderer) to the image size and render
                imagePainter = QPainter(image)
                zoom = 1
                target_dpi = int(round(zoom * mapRenderer.outputDpi()))
                mapRenderer.setOutputSize(QSize(width, height), target_dpi)
                mapRenderer.render(imagePainter)
                imagePainter.end()
                xN = mapRect.xMinimum()
                yN = mapRect.yMinimum()
                nomePNG = ("TestImage")
                input_file = out_folder + "/" + nomePNG + ".png"
                image.save(input_file, "png")
So, my question is :  how need to change my code to have labels again
visible ?
Thank you for any link and answer
Roberto
2014-10-05 22:18 GMT+02:00 Anita Graser <anitagraser at gmx.at>:
> Am 05.10.2014, 18:54 Uhr, schrieb Larry Shaffer <larrys at dakotacarto.com>:
>> Here's a small script you can use to test the Python bindings for labeling
> Thanks a lot Larry! I'll give it a try!
>  Feel free to add this to the Cookbook. However, the API for labeling may
>> change during the 2.7 dev cycle, if rule- and style-based labeling is
>> introduced.
> You mean it will change without breaking it? ;-)
> Best wishes,
> Anita
> anitagraser.com
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141006/4d673208/attachment.html>
