[Qgis-developer] Custom SVG issue in QGIS API
Tendfly niu niubob at hotmail.com
Mon Oct 13 00:39:34 PDT 2014
Hi all,
         I'm using QGIS-2.4.0 API to developing application.
I wrote a custom map canvas item called MyMapCanvasItemSvg that show SVG
items in canvas.
It is well to load and display SVG from symbol library of QGIS (i.e. file
path: d:\QGIS Chugiak\apps\qgis\svg\symbol\*.svg),
But when I create a svg file using Adobe Illustrator 16.0.0(which is same as
Generator of symbol library's svg), it breaks.
I don't know the key point of SVG, I searched the topic on mailing list,
only found the topic"Custom Symbology and Inkscape"(link
<http://osgeo-org.1560.x6.nabble.com/Custom-Symbology-and-Inkscape-td4139425
.html#a4139427> ),
It don't help.
Any advice appricated!
Here are parts of my MyMapCanvasItemSvg codes:
void paint(QPainter *painter)
         QImage svgImage(29, 29, QImage::Format_ARGB32);
         QPainter imagePainter(&svgImage);
         mSvgRenderer.render(&imagePainter);          //mSvgRenderer is a
object of QSvgRenderer, constructed using a svg file path
         painter->drawImage(QrectF(0, 0, 100, 80), svgImage, QRectF(0, 0,
100, 80));
Regards,
Bob
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141013/98ccce12/attachment.html>
