[Qgis-developer] how to set square symbol in a point layer with python
Stefano Masera
stefano.masera at arpa.piemonte.it
Mon Oct 13 02:51:17 PDT 2014
Thanks for the answer!
Sorry but I didn't understand how to use QgsSimpleMarkerSymbolLayerV2.
I did some attempt but I didn't manage..
Below there's my code (with only two symbol item as example)
myTargetField = field
myRangeList = []
myOpacity = 1
# symbol 1
mySymbol = QgsSymbolV2.defaultSymbol(layer.geometryType())
mySymbol.setColor(QColor('#FFFFFF'))
mySymbol.setAlpha(myOpacity)
myRange = QgsRendererRangeV2(0.1,34.4,mySymbol,"< 35")
myRangeList.append(myRange)
# symbol 2
mySymbol.setColor(QColor('#238443'))
myRange = QgsRendererRangeV2(34.5,39.4,mySymbol,"35 - 39 dB(A)")
# other symbol items
myRenderer = QgsGraduatedSymbolRendererV2('', myRangeList)
myRenderer.setMode(QgsGraduatedSymbolRendererV2.EqualInterval)
myRenderer.setClassAttribute(myTargetField)
layer.setRendererV2(myRenderer)
iface.legendInterface().refreshLayerSymbology(layer)
layer.triggerRepaint()
And I want that symbol 1 became a square.
I can't understand how to use QgsSimpleMarkerSymbolLayerV2.
Sorry and thank you!
C
S
----- Messaggio originale -----
Da: "Salvatore Larosa" <lrssvtml at gmail.com>
A: "Stefano Masera" <stefano.masera at arpa.piemonte.it>
Cc: "qgis-developer" <qgis-developer at lists.osgeo.org>
Inviato: Lunedì, 13 ottobre 2014 11:21:37
Oggetto: Re: [Qgis-developer] how to set square symbol in a point layer with python
On Mon, Oct 13, 2014 at 10:11 AM, Stefano Masera
<stefano.masera at arpa.piemonte.it> wrote:
> Hi list,
> I wan't to set a square symbol in a point layer with python.
> Currently, I use a graduated symbol legend, and I have a circle (point)
> symbol with this line for each item:
> symbol = QgsSymbolV2.defaultSymbol(layer.geometryType())
> But I want to set a square for one item.
> How can I do?
after having got the symbol layer (QgsSimpleMarkerSymbolLayerV2) you
can use the setName() method to change from circle (default) to any
other symbol. In your case setName("square").
Regards,
-SL
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141013/5b2e5ef2/attachment.html>
