[Qgis-developer] QGIS crash during testing of my plugin
Luca Delucchi lucadeluge at gmail.com
Tue Oct 14 03:19:03 PDT 2014
On 14 October 2014 11:51, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> Hi Luca,
Hi Salvatore,
> just type py-bt [0] onto gdb prompt, you need of the python extension
> for debugging though.
I'm still not able to run it, I installed all the needed software.
These are my steps:
- run "gdb qgis"
- inside gdb type "run" this execute qgis
- now try to crash qgis
- type "py-bt" but the result is
 (gdb) py-bt
 Undefined command: "py-bt".  Try "help".
Instead if I run only "bt" I obtain some output (the following one is
the complete output of gdb)
 (gdb) run
Starting program: /usr/local/bin/qgis
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Warning: loading of qt translation failed [/usr/share/qt4/translations/qt_en_GB]
Warning: QGraphicsScene::addItem: item has already been added to this scene
[New Thread 0x7fffd2b97700 (LWP 31012)]
[New Thread 0x7fff92294700 (LWP 31013)]
[New Thread 0x7fff91540700 (LWP 31014)]
[New Thread 0x7fff676b4700 (LWP 31019)]
[Thread 0x7fff676b4700 (LWP 31019) exited]
Program received signal SIGSEGV, Segmentation fault.
0x00007fff80330559 in ?? () from
/usr/lib/python2.7/dist-packages/PyQt4/QtCore.so
(gdb) bt
#0  0x00007fff80330559 in ?? () from
#1  0x00007ffff2855919 in QMetaObject::cast(QObject*) const () from
/usr/lib/x86_64-linux-gnu/libQtCore.so.4
#2  0x00007ffff1fe0e9c in QMdiArea::eventFilter(QObject*, QEvent*) ()
from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#3  0x00007fff7faeb566 in ?? () from
/usr/lib/python2.7/dist-packages/PyQt4/QtGui.so
#4  0x00007ffff284ed82 in
QCoreApplicationPrivate::sendThroughApplicationEventFilters(QObject*,
QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#5  0x00007ffff1ba42a8 in QApplicationPrivate::notify_helper(QObject*,
QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#6  0x00007ffff1baae18 in QApplication::notify(QObject*, QEvent*) ()
#7  0x00007ffff3e82a37 in QgsApplication::notify(QObject*, QEvent*) ()
from /usr/local/lib/libqgis_core.so.2.5.0
#8  0x00007ffff284ecad in QCoreApplication::notifyInternal(QObject*,
#9  0x00007ffff1ba6547 in QApplicationPrivate::enterModal(QWidget*) ()
#10 0x00007ffff1bf48c8 in QWidgetPrivate::show_helper() () from
#11 0x00007ffff1bf674a in QWidget::setVisible(bool) () from
#12 0x00007ffff20784ae in QDialog::setVisible(bool) () from
#13 0x00007fff7fcb389c in ?? () from
#14 0x00007ffff2078876 in QDialog::exec() () from
#15 0x00007fff7fc69205 in ?? () from
#16 0x00007fff80ba9a8c in call_function (oparg=<optimized out>,
pp_stack=<optimized out>) at ../Python/ceval.c:4021
#17 PyEval_EvalFrameEx (f=0x7fff88151050, throwflag=1746239640) at
../Python/ceval.c:2667
#18 0x00007fff80c1ccf0 in PyEval_EvalCodeEx (co=0x7fff7cc9ddb0,
globals=0x7fff80125780, locals=0x7fffffffbb60, locals at entry=0x0,
args=0x7fff6f9dd228, argcount=2144122026,
    kws=0xedd480 <QHashData::shared_null>, kws at entry=0x0, kwcount=0,
defs=0x0, defcount=0, closure=0x0) at ../Python/ceval.c:3253
#19 0x00007fff80b6be3c in function_call.lto_priv.328
(func=0x7fff7cc03d70, arg=0x7fff6f9dd210, kw=0x0) at
../Objects/funcobject.c:526
#20 0x00007fff80b74873 in PyObject_Call (func=0x7fff7cc03d70,
arg=<optimized out>, kw=<optimized out>) at ../Objects/abstract.c:2529
#21 0x00007fff80bb6c55 in instancemethod_call.lto_priv.243
(func=0x7fff67ea5938, arg=0x7fff88151050, kw=0x0) at
../Objects/classobject.c:2602
#22 0x00007fff80b74873 in PyObject_Call
(func=func at entry=0x7fff67f80be0, arg=arg at entry=0x7fff88151050,
#23 0x00007fff80c1c247 in PyEval_CallObjectWithKeywords
(func=0x7fff67f80be0, arg=0x7fff88151050, kw=<optimized out>) at
../Python/ceval.c:3890
#24 0x00007fff80622390 in sip_api_invoke_slot_ex () from
/usr/lib/python2.7/dist-packages/sip.so
#25 0x00007fff8032ca92 in ?? () from
#26 0x00007fff8032cddd in ?? () from
#27 0x00007fff8032d98d in ?? () from
#28 0x00007ffff2863ffb in QMetaObject::activate(QObject*, QMetaObject
const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#29 0x00007ffff1b9db22 in QAction::triggered(bool) () from
#30 0x00007ffff1b9f6c7 in QAction::activate(QAction::ActionEvent) ()
#31 0x00007ffff1ff309d in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#32 0x00007ffff1ff7a69 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#33 0x00007fff7fae5fbb in ?? () from
#34 0x00007ffff1bf73b8 in QWidget::event(QEvent*) () from
#35 0x00007ffff1ffba4b in QMenu::event(QEvent*) () from
#36 0x00007fff7fae49fb in ?? () from
#37 0x00007ffff1ba431c in QApplicationPrivate::notify_helper(QObject*,
#38 0x00007ffff1baaf7f in QApplication::notify(QObject*, QEvent*) ()
#39 0x00007ffff3e82a37 in QgsApplication::notify(QObject*, QEvent*) ()
#40 0x00007ffff284ecad in QCoreApplication::notifyInternal(QObject*,
#41 0x00007ffff1baa5af in
QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*,
QWidget*, QWidget**, QPointer<QWidget>&, bool) () from
#42 0x00007ffff1c2168d in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#43 0x00007ffff1c1fcb2 in QApplication::x11ProcessEvent(_XEvent*) ()
#44 0x00007ffff1c48f92 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
---Type <return> to continue, or q <return> to quit---
#45 0x00007fffed32cc5d in g_main_context_dispatch () from
/lib/x86_64-linux-gnu/libglib-2.0.so.0
#46 0x00007fffed32cf48 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#47 0x00007fffed32cffc in g_main_context_iteration () from
#48 0x00007ffff287e14d in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#49 0x00007ffff1c49056 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#50 0x00007ffff284d801 in
QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) ()
#51 0x00007ffff284db65 in
QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from
#52 0x00007ffff28535c7 in QCoreApplication::exec() () from
#53 0x0000000000574b3c in main ()
(gdb) continue
Continuing.
QGIS died on signal 11warning: process 31008 is already traced by process 31006
ptrace: Operation not permitted.
No thread selected
No stack.
gdb returned 0
Program received signal SIGABRT, Aborted.
0x00007fffef17c077 in __GI_raise (sig=sig at entry=6) at
../nptl/sysdeps/unix/sysv/linux/raise.c:56
56      ../nptl/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) continue
Continuing.
[Thread 0x7fff92294700 (LWP 31013) exited]
[Thread 0x7fffd2b97700 (LWP 31012) exited]
[Thread 0x7ffff7f887c0 (LWP 31008) exited]
Program terminated with signal SIGABRT, Aborted.
The program no longer exists.
(gdb)
Is there any other way to run it?
> Regards,
> -SL
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
