[Qgis-developer] Invisible shapefile
Even Rouault even.rouault at spatialys.com
Sat Oct 18 04:59:21 PDT 2014
Le samedi 18 octobre 2014 13:35:43, Paolo Cavallini a écrit :
> Il 18/10/2014 13:24, Even Rouault ha scritto:
> > Have you compared the output of ogrinfo -al on the shapefile after SAGA
> > has created it, and after resaving ?
> Thanks Even. The wrong one has:
> Extent: (nan, nan) - (nan, nan)
> However, updating the extent from QGIS vector propertires does not solve
> the issue.
It is likely that the OGR Shapefile driver doesn't do right things with such
extent. Perhaps always filtering out features when spatial filter is defined.
> Seems more of a problem with SAGA though.
> Do you think I should open a ticket upstream?
Yes, that should likely be fixed on SAGA side.
Perhaps OGR could also better react in that case. Perhaps open a ticket in
GDAL trac with the shapefile attached.
> All the best.
http://www.spatialys.com
