[Qgis-developer] Invisible shapefile
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Sun Oct 19 02:00:31 PDT 2014
There seems to be a problem with SAGA's shapefile writer/reader. See this:
http://hub.qgis.org/issues/11007
Cheers,
Saber
-----Original Message-----
[mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
Sent: 18 October 2014 17:01
To: Even Rouault
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Invisible shapefile
Il 18/10/2014 13:59, Even Rouault ha scritto:
>> Seems more of a problem with SAGA though.
>> Do you think I should open a ticket upstream?
> Yes, that should likely be fixed on SAGA side.
Done: https://sourceforge.net/p/saga-gis/bugs/197/
> Perhaps OGR could also better react in that case. Perhaps open a
> ticket in GDAL trac with the shapefile attached.
Done: http://trac.osgeo.org/gdal/attachment/ticket/5702/
Thanks.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
