[Qgis-developer] Problems with Raster calculator (SAGA) on Win8
Paolo Cavallini cavallini at faunalia.it
Fri Oct 24 02:54:21 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
On Windows 8, the interface for raster calculator is missing the first
dropdown (with "a" raster). Possibly as a result, we cannot complete
the analyses. See error below.
Is this confirmed, or a local problem?
All the best.
SAGA execution console output
C:UsersCERI-03Desktopcorso analisi QGIS>set
SAGA=C:/PROGRA~2/QGISVA~1/appssaga
SAGA_MLB=C:/PROGRA~2/QGISVA~1/appssagamodules
QGIS>PATH=PATH;C:/PROGRA~2/QGISVA~1/appssaga;C:/PROGRA~2/QGISVA~1/appssagamodules
C:UsersCERI-03Desktopcorso analisi QGIS>saga_cmd grid_tools
"Resampling" -INPUT
"C:UsersCERI-03AppDataLocalTempprocessinga7886fe52cac462797d5a42eda159efeaccflow.sgrd"
- -TARGET 0 -SCALE_UP_METHOD 0 -SCALE_DOWN_METHOD 0 -USER_XMIN
262846.525725 -USER_XMAX 277871.525725 -USER_YMIN 4454025.0 -USER_YMAX
4464275.0 -USER_SIZE 25.0 -USER_GRID
"C:UsersCERI-03AppDataLocalTempprocessing1414139466.262.sgrd"
_____________________________________________
library path: C:/PROGRA~2/QGISVA~1/appssagamodules
library name: grid_tools
module name : Resampling
author : O.Conrad (c) 2003
go...
error: input file
[C:UsersCERI-03AppDataLocalTempprocessinga7886fe52cac462797d5a42eda159efeaccflow.sgrd]
Usage: Resampling -INPUT <str> [-INPUT_ADD <str>] [-OUTPUT_ADD <str>]
[-KEEP_TYPE] [-TARGET <str>] [-SCALE_UP_METHOD <str>]
[-SCALE_DOWN_METHOD <str>] [-USER_XMIN <str>] [-USER_XMAX <str>]
[-USER_YMIN <str>] [-USER_YMAX <str>] [-USER_SIZE <str>] [-USER_GRID
<str>] [-GRID_GRID <str>]
- -INPUT:<str> Grid
Grid (input)
- -INPUT_ADD:<str> Additional Grids
Grid list (optional input)
- -OUTPUT_ADD:<str> Additional Grids
Grid list (optional output)
- -KEEP_TYPE Preserve Data Type
Boolean
- -TARGET:<str> Target Grid
Choice
Available Choices:
[0] user defined
[1] grid
- -SCALE_UP_METHOD:<str> Interpolation Method
Choice
Available Choices:
[0] Nearest Neighbor
[1] Bilinear Interpolation
[2] Inverse Distance Interpolation
[3] Bicubic Spline Interpolation
[4] B-Spline Interpolation
[5] Mean Value
[6] Mean Value (cell area weighted)
[7] Minimum Value
[8] Maximum Value
[9] Majority
- -SCALE_DOWN_METHOD:<str> Interpolation Method
Choice
Available Choices:
- -USER_XMIN:<str> Left
Floating point
- -USER_XMAX:<str> Right
Floating point
- -USER_YMIN:<str> Bottom
Floating point
- -USER_YMAX:<str> Top
Floating point
- -USER_SIZE:<str> Cellsize
Floating point
Minimum: 0.000000
- -USER_GRID:<str> Grid
Data Object (optional output)
- -GRID_GRID:<str> Grid
Grid (output)
error: executing module [Resampling]
"Resampling" -INPUT
"C:UsersCERI-03AppDataLocalTempprocessingb7e47e4fc0e34cd3b4479b27d9577450dem25.sgrd"
"C:UsersCERI-03AppDataLocalTempprocessing1414139466.263.sgrd"
go...
error: input file
[C:UsersCERI-03AppDataLocalTempprocessingb7e47e4fc0e34cd3b4479b27d9577450dem25.sgrd]
- -INPUT:<str> Grid
Grid (input)
Boolean
Choice
Available Choices:
[0] user defined
[1] grid
Choice
Available Choices:
[5] Mean Value
[7] Minimum Value
[8] Maximum Value
[9] Majority
Choice
Available Choices:
Floating point
Floating point
Floating point
Floating point
Floating point
Minimum: 0.000000
Grid (output)
C:UsersCERI-03Desktopcorso analisi QGIS>saga_cmd grid_calculus "Grid
Calculator" -GRIDS
"C:UsersCERI-03AppDataLocalTempprocessing1414139466.262.sgrd;C:UsersCERI-03AppDataLocalTempprocessing1414139466.263.sgrd"
- -FORMULA "a/a*b" -RESULT
"C:UsersCERI-03AppDataLocalTempprocessing89fba9610bb84594a830da8349c9f342RESULT.tif.sgrd"
library name: grid_calculus
module name : Grid Calculator
author : Copyrights (c) 2003 by Andre Ringeler
go...
Load grid: C:UsersCERI-03AppDataLocalTempprocessing1414139466.262.sgrd...
failed
Load grid: C:UsersCERI-03AppDataLocalTempprocessing1414139466.263.sgrd...
failed
error: Grid file could not be opened.
error: input file
[C:UsersCERI-03AppDataLocalTempprocessing1414139466.262.sgrd]
error: input file
[C:UsersCERI-03AppDataLocalTempprocessing1414139466.263.sgrd]
error: empty input list [GRIDS]
Usage: Grid Calculator -GRIDS <str> [-XGRIDS <str>] -RESULT <str>
[-FORMULA <str>] [-NAME <str>] [-FNAME] [-USE_NODATA]
- -GRIDS:<str> Grids
Grid list (input)
- -XGRIDS:<str> Grids from different Systems
- -RESULT:<str> Result
Grid (output)
- -FORMULA:<str> Formula
Text
- -NAME:<str> Name
Text
- -FNAME Take Formula
Boolean
- -USE_NODATA Use NoData
Boolean
error: executing module [Grid Calculator]
C:UsersCERI-03Desktopcorso analisi QGIS>saga_cmd io_gdal 1 -GRIDS
- -FORMAT 4 -TYPE 0 -FILE
"C:UsersCERI-03AppDataLocalTempprocessing89fba9610bb84594a830da8349c9f342RESULT.tif"
ERROR 1: Can't load requested DLL:
C:PROGRA~2QGISWE~1bingdalpluginsgdal_ECW_JP2ECW.dll
126: Impossibile trovare il modulo specificato.
C:PROGRA~2QGISWE~1bingdalpluginsgdal_MG4Lidar.dll
C:PROGRA~2QGISWE~1bingdalpluginsgdal_MrSID.dll
library name: io_gdal
module name : GDAL: Export Raster
author : O.Conrad (c) 2007
go...
Load grid:
C:UsersCERI-03AppDataLocalTempprocessing89fba9610bb84594a830da8349c9f342RESULT.tif.sgrd...
failed
error: input file
[C:UsersCERI-03AppDataLocalTempprocessing89fba9610bb84594a830da8349c9f342RESULT.tif.sgrd]
Usage: 1 -GRIDS <str> [-FILE <str>] [-FORMAT <str>] [-TYPE <str>]
- -GRIDS:<str> Grid(s)
Grid list (input)
- -FILE:<str> File
File path
- -FORMAT:<str> Format
Choice
Available Choices:
[0] Virtual Raster
[1] GeoTIFF
[2] National Imagery Transmission Format
[3] Erdas Imagine Images (.img)
[4] ELAS
[5] In Memory Raster
[6] MS Windows Device Independent Bitmap
[7] PCIDSK Database File
[8] ILWIS Raster Map
[9] SGI Image File Format 1.0
[10] Leveller heightfield
[11] Terragen heightfield
[12] ERMapper .ers Labelled
[13] Raster Matrix Format
[14] Idrisi Raster A.1
[15] Intergraph Raster
[16] Golden Software Binary Grid (.grd)
[17] Portable Pixmap Format (netpbm)
[18] ENVI .hdr Labelled
[19] ESRI .hdr Labelled
[20] PCI .aux Labelled
[21] Vexcel MFF Raster
[22] Vexcel MFF2 (HKV) Raster
[23] VTP .bt (Binary Terrain) 1.3 Format
[24] Image Data and Analysis
[25] NOAA Vertical Datum .GTX
[26] NTv2 Datum Grid Shift
[27] ARC Digitized Raster Graphics
[28] SAGA GIS Binary Grid (.sdat)
- -TYPE:<str> Data Type
Choice
Available Choices:
[0] match input data
[1] 8 bit unsigned integer
[2] 16 bit unsigned integer
[3] 16 bit signed integer
[4] 32 bit unsigned integer
[5] 32 bit signed integer
[6] 32 bit floating point
[7] 64 bit floating point
error: executing module [GDAL: Export Raster]
C:UsersCERI-03Desktopcorso analisi QGIS>exit
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iEYEARECAAYFAlRKIcIACgkQ/NedwLUzIr6G5gCbBcguzwP9ZK3KqqgoKcpZiiWp
AGkAnjqF818uuqeELnK24+NecL1aOAsq
=5XNy
-----END PGP SIGNATURE-----
