[Qgis-developer] data defined fill/border colors: what to show in legend?
Giovanni Manghi giovanni.manghi at faunalia.pt
Sun Oct 26 04:46:41 PDT 2014
Hi all, there is an ongoing discussion about this matter here
http://hub.qgis.org/issues/11491
In case you are not aware: if you use data defined fill/border colors
for a vector, the legend will show the symbology classes (in case you
are using the categorized symbology), but the symbol for all the
classes will be a nice black square instead of the expected
colors/borders (let's assume that the user has created the table the
right way, with only one color per class).
There is a technical answer by Jürgen, but anyway a decision must be taken.
Do we expect to see the classes and the (data defined colors)? Or when
using data defined colors we do expect another thing?
cheers
-- G --
