[Qgis-developer] VRT functionality
Even Rouault even.rouault at spatialys.com
Sun Oct 26 10:22:54 PDT 2014
Le dimanche 26 octobre 2014 16:44:37, Zoltan Szecsei a écrit :
> Hi,
> I just want to clear up my mindset as to how a VRT is implemented in QGIS.
Zoltan,
In fact those are more OGR questions than QGIS questions. QGIS makes no
difference when reading a plain shapefile (through OGR) or a VRT.
> I'd like to understand when QGIS opens a file, when it reads the
> contents, and when it writes (if need be) and closes a file.
> In this context, I am thinking about SHP files - especially the NGI
> dataset which comes out "cut up" into degree squares.
> Let's just deal with 1 feature type: Rivers lines. My VRT looks like:
> <OGRVRTDataSource>
>    <OGRVRTUnionLayer name="Rivers">
>    <OGRVRTLayer name="2730_RIVER_LINE_2006_06">
>      <SrcDataSource
> relativeToVRT="1">2730/2730_RIVER_LINE_2006_06.shp</SrcDataSource>
>    </OGRVRTLayer>
>    <OGRVRTLayer name="2731_RIVER_LINE_2006_04">
>      <SrcDataSource
> relativeToVRT="1">2731/2731_RIVER_LINE_2006_04.shp</SrcDataSource>
>    </OGRVRTLayer>
>    <OGRVRTLayer name="2732_RIVER_LINE_2006_04">
>      <SrcDataSource
> relativeToVRT="1">2732/2732_RIVER_LINE_2006_04.shp</SrcDataSource>
>    </OGRVRTLayer>
>    </OGRVRTUnionLayer>
> </OGRVRTDataSource>
>   * When I open the VRT in QGIS, does QGIS open ALL the VRT files and
>     look for the extent of each of the files?
If QGIS issues a GetExtent() on the VRT, then with the above definition, it
will query the 3 shapefiles to find the extent of each. But on shapefiles this is
a fast operation.
You could define <ExtentXMin>, etc... just besides OGRVRTUnionLayer if you
really want fast GetExtent()
>       o If my VRT had the extents included for each of the files, would
>         this stop QGIS from (at this stage) opening the files and
>         reading the extents?
Yes, but QGIS probably asks GetFeatureCount(), so it will need to open each
shapefile, unless you define <FeatureCount> as well.
But QGIS will also asks the field definition, and will need to open each ....,
unless you define <Field>
>   * Before rendering the VRT, does QGIS look at the extents of my
>     viewport and only physically open my files and render it's contents?
QGIS will define SetSpatialFilter() on the layer with the extent, so as the
layer can use a spatial index if it has one. Reviewing my code in VRT union
layer, I can see that the spatial filter will be forwarded to each source
layer. So it will need to open them, but the shapefile driver won't scan any
feature if setting a spatial filter that does not intersect the extent of the
shapefile, so that should be fast. A possible optimization could be done in the
VRT union layer to take into account the extent of the source layer to avoid
iterating on it if the spatial filter on th union layer doesn't intersect that
extent.
To be efficient, you likely need to compute .qix spatial index on each shapefile.
>     In other words, if I first zoom into a known area, then open my VRT,
>     will QGIS at this stage still open all the subfiles, instead of
>     waiting until a specific subfile needs opening)
>   * As I pan around my map, does QGIS open and close the VRT subfiles
>     that are out of my current viewing region?
The VRT driver will maintain a pool of a maximum of 100 source layers by
default (that number can be altered by setting the OGR_VRT_MAX_OPENED
configuration option) and will close transparently the older ones
>   * Presumably if any of my VRT subfiles touch or overlap my current
>     viewport, they would be "processed" depending on what I am doing?
>   * Is there a way to structure a VRT file so that you can have access
>     to the underlying files that make up the VRT? (Even edit access?)
Not sure what you mean by "have access to". But a union VRT can be opened in
update mode and the update mode will be forwareded to the source layers
(provided they support it). You can delete or modify features. For creation of
new features, you need to specify <SourceLayerFieldName> as documented in
http://gdal.org/drv_vrt.html
> Or, is the VRT just any easy way to bunch a whole lot of maps under one
> name, and there is no processing benefit depending on the area you are
> viewing or working in?
Your above VRT should work reasonably fast. Unless you have several hunderds
or thousands of source layers. In which case, you may need to define more
optional elements in the VRT to avoid the scans, and there would be perhaps a
need for some enhancements in the OGRUnionLayer class.
Even
http://www.spatialys.com
