[Qgis-developer] Layer comparision/suitability
Jorge Tornero - Listas
jtorlistas at gmail.com
Mon Sep 1 00:26:04 PDT 2014
I've developed a plugin in which the user has the ability to create a
new layer with some certain fields (say, for instance, color, size,
shape) or use and existing one, in that case the fields can be added to
the layer.
I have implemented a "brute force" comparision: I check in the existing
layer for the existence of those fields and of the same type. You could
see how in this gist:
https://gist.github.com/jtornero/fbc9928720da2de364f1
Unfortunately, it doesn't seem to work very well at all. I wonder if
someone has faced this problem before or could suggest another approach.
Thank you very much.
All the best,
Jorge
