[Qgis-developer] Building QGIS 2.x with Qt 5.x?
Matthias Kuhn matthias.kuhn at gmx.ch
Tue Sep 2 11:41:49 PDT 2014
Hi Dave,
I have ported large portions of the code to Qt5 (for Android). It has
not been widely tested but runs quite stable here on Fedora (so not far
from RHEL). However, due to missing pyqt packages I could not test
python support (arriving in Fedora 21). If you want to give it a try,
you can find the code here [1]
Good luck and let me know how it goes.
Matthias
[1] https://github.com/m-kuhn/QGIS/tree/final-2_4_0-qt5
On Die 02 Sep 2014 20:38:28 CEST, Dave Johansen wrote:
> http://gis.stackexchange.com/questions/62548/can-i-use-qgis-with-qt5
> The above link indicates that QGIS 2.x can't be built with Qt 5.x and
> I was curious how much work would be involved in resolving that.
> I ask because I'm using RHEL 6 which comes with Qt 4.6 and so I can't
> build QGIS 2.x with that because it requires 4.7. Qt 5.x is available
> in the EPEL so I was wondering what would be involved in making it so
> I could use that. If it's not too big of an effort, then I could
> potentially help with the work but I wanted to find out what it would
> involve before I dove into anything.
> Thanks,
> Dave
> Qgis-developer mailing list
