[Qgis-developer] qgis server can't enable logging
Uros Preloznik
uros00 at gmail.com
Tue Sep 2 11:49:15 PDT 2014
Added pullrequest to documentation.
https://github.com/qgis/QGIS-Documentation/pull/250
regards
Uros
Date: Thu, 28 Aug 2014 15:47:16 +0200
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] qgis server can't enable logging
Il 28/08/2014 12:47, Uros Preloznik ha scritto:
> Hi,
> Thanks Alessandro, this is working now. I was trying only with SetEnv. I
also had to
> set QGIS_SERVER_LOG_LEVEL, otherwise the file was empty. So this is my
setting now
> which is working (Apache+Fcgid):
> FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/tmp/qgislog.txt
> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
> LogLevel 0 means that everything is logged, for debugging only.
> Is someone working on documentation? This could be included for others.
>Hi Uros,
>would you mind making a pull request on
>Thanks.
>Paolo Cavallini - www.faunalia.eu
>Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140902/d78cc3cb/attachment-0001.html>
