[Qgis-developer] in-memory layer as cache in DBManager
Tim Sutton tim at kartoza.com
Tue Sep 2 12:27:23 PDT 2014
Hi
On Tue, Sep 2, 2014 at 9:04 , mederic.ribreux
<mederic.ribreux at medspx.homenet.org> wrote:
> Hello devs,
> during my work on DBManager Oracle implementation, I've been faced
> with
> large layers that take time to open (more than 10 seconds is quite a
> lot
> for the users in my office). It is even worse with dynamic queries
> because QGis considers that there is no spatial indexes available
> (which
> is true on most cases). In this situation, it takes the same amount
> of
> time to show a limited set of data and the whole set.
> Other GIS tools (ArcGIS 10.x and MapInfo 10.x) provide a very basic
> cache feature. Once the layer (or query) content has been loaded in
> memory, every operation (scan/pan or geoprocessing) is really fast
> (about milliseconds compared to more than 10 seconds). There is no
> cache
> synchronisation mechanisms but it just works (from the user point of
> view).
> I know that there has been discussions about implementing a cache
> mechanism in QGis but I see nothing in the code for the moment
> (perhaps
> am I wrong ?).
> I think that for the moment, in-memory layers are the nearest
> approach
> for a cache system. They have been deployed long ago and I think that
> we
> can work with them to offer a very basic-but-easy-to-use cache
> mechanism.
> I've played so far with Python code to make an in-memory layer from a
> (what I think is becoming a) big Oracle table (about 250000 objects).
> Performances are quite good: it takes about one second more to build
> the
> in-memory layer than retrieving the whole dataset (17 seconds). Data
> are
> transfered only once during the copy features operation, so the total
> amount of time of building the in-memory layer is the time of the
> query
> duration. Once the in-memory layer is loaded, you can pan and zoom at
> all levels in less than one second. The only drawback I've found so
> far
> is some freezing on attributes table. It takes about ten seconds to
> open
> the attributes table and scrolling in it is very slow. I've noticed
> that
> when you replace floats fields by integer ones, scrolling is a little
> bit faster.
>  From the user point of view, in-memory layers are similar to a basic
> caching system:
> - you grab all the data from the SRDBMS the first time you open the
> layer.
> - Then you are able to do fast data analysis or rendering...
> - knowing that if you want to work on true live data, you have to
> open
> the real layer (no synchronisation).
> For the moment, the only practical way for a user to build an
> in-memory
> layer is by selecting all the features of a layer (which takes time
> as
> selection launches a refresh query), copy them into clipboard and
> clip
> them in an in-memory layer. Furthermore, this technique doesn't work
> with Date/Time attributes (the layer cannot be created).
> You can build in-memory copies of a layer by using the Python console
> but this is not really user-friendly. I believe that a good entry
> point
> to load an in-memory layer is in DBManager, on the dbtree or in the
> SQL
> editor widget.
> Why add this new functionnality there ? First, just because the
> Python
> implementation is easier to code and there will be no modification on
> the core code of QGis. Then it seems that the performances will be
> good.
> Furthermore, SQL queries made with the SQL dialog box of the plugin
> are
> good candidates to in-memory layers. Loading them as in-memory layers
> can be faster than building them and saving them in a local file
> (data
> are transfered only once from the SRDBMS server).
> I'd like to know what do you think about this practical approach of
> caching ? Do you think it is a good idea to just add a button or a
> checkbox or a menu entry to load a layer or an SQL query as an
> in-memory
> layer ? Do you think DBManager is a good candidate for this user
> interface ?
> Best regards,
I think this approach is only useful for read only layers (and ones
that can fit easily in available memory).
> PS: I know that the ideal situation would be a true cache mechanism
> directly on core code but (I think) it is far more complex to
> implement...
Martin Dobias was interested and available to work on a proper caching
machanism - he just needs some funding. Personally I would rather hold
out for a proper caching mechanism that synchronises writes on both
client server and client side and perhaps has some smarts about what to
cache.
Regards
Tim
> Médéric RIBREUX
> http://medspx.homenet.org
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140902/ea4ab740/attachment.html>
