[Qgis-developer] Crash of QGIS 2.4 built on RHEL 6 with Qt 5.3
Dave Johansen davejohansen at gmail.com
Fri Sep 5 11:24:33 PDT 2014
On Thu, Sep 4, 2014 at 11:38 PM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Hi Dave
> there is still Qt 4 involved (partially?) as the 4 in the end of this line
> indicates:
> #10 0x00007ffff3e24ce6 in __do_global_ctors_aux () from
> /usr/lib64/libQtCore.so.4
> Did you clean the build directory after the build attempts for master?
I just did a complete clean build just to be sure and it had the same
crash. The same crash happened. Here's the output from ldd grepped for qt:
    libQt5Sql.so.5 => /usr/lib64/libQt5Sql.so.5 (0x000000357c400000)
    libQt5WebKit.so.5 => /usr/lib64/libQt5WebKit.so.5 (0x0000003585200000)
    libQt5WebKitWidgets.so.5 => /usr/lib64/libQt5WebKitWidgets.so.5
(0x0000003580000000)
    libqgis_core.so.2.4.0 =>
/home/dlj/projects/qgis-qt5/build/../install/lib/libqgis_core.so.2.4.0
(0x00007faf1211c000)
    libqgis_gui.so.2.4.0 =>
/home/dlj/projects/qgis-qt5/build/../install/lib/libqgis_gui.so.2.4.0
(0x00007faf11a01000)
    libqgis_analysis.so.2.4.0 =>
/home/dlj/projects/qgis-qt5/build/../install/lib/libqgis_analysis.so.2.4.0
(0x00007faf11772000)
    libQt5Quick.so.5 => /usr/lib64/libQt5Quick.so.5 (0x000000357c800000)
    libQt5Qml.so.5 => /usr/lib64/libQt5Qml.so.5 (0x000000357b200000)
    libQt5OpenGL.so.5 => /usr/lib64/libQt5OpenGL.so.5 (0x000000357f400000)
    libQt5Sensors.so.5 => /usr/lib64/libQt5Sensors.so.5 (0x000000357fc00000)
    libQt5Network.so.5 => /usr/lib64/libQt5Network.so.5 (0x0000003579e00000)
    libQt5PrintSupport.so.5 => /usr/lib64/libQt5PrintSupport.so.5
(0x000000357ee00000)
    libQt5Positioning.so.5 => /usr/lib64/libQt5Positioning.so.5
(0x000000357f800000)
    libQt5Xml.so.5 => /usr/lib64/libQt5Xml.so.5 (0x000000357a200000)
    libQt5Concurrent.so.5 => /usr/lib64/libQt5Concurrent.so.5
(0x00007faf1133c000)
    libQt5Svg.so.5 => /usr/lib64/libQt5Svg.so.5 (0x00007faf110eb000)
    libQt5Widgets.so.5 => /usr/lib64/libQt5Widgets.so.5 (0x000000357ba00000)
    libQt5Gui.so.5 => /usr/lib64/libQt5Gui.so.5 (0x000000357aa00000)
    libQt5Core.so.5 => /usr/lib64/libQt5Core.so.5 (0x0000003578a00000)
    libQtSvg.so.4 => /usr/lib64/libQtSvg.so.4 (0x0000003582200000)
    libQtGui.so.4 => /usr/lib64/libQtGui.so.4 (0x00007faf0fda5000)
    libQtCore.so.4 => /usr/lib64/libQtCore.so.4 (0x00007faf0f941000)
So it looks like you already pointed out that the Qt4 libraries are being
linked in as well for some reason. Any ideas on what I should do to run
down where this issue is coming from?
> For your other question (lrelease-qt5) you can revert this commit:
> 9c6f1698fcb3df758f024fad99ed6506d6a38e0d
> I guess I'll have to figure out another approach to handle this suffix
> than just deleting it like this commit does.
I reverted that commit and it built without me specifying the path to
lrelease-qt5.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140905/f6d99b3b/attachment.html>
