[Qgis-developer] Proposal: move the "Remove layer(s)" button
aperi2007
aperi2007 at gmail.com
Fri Sep 5 23:31:33 PDT 2014
I know this,
but my response is enlarged to a more conceptual problem.
How avoid that an user could be confusing from when it act on a logical
level of interface,
and when it act on a physical data.
I understand that removing mean always remove and so 1 only button is
better than two.
But my question is :
if we remove the "remove layers" leaving only the "remove this" that is
available in the context-menu (i dont see the new legend again).
Seem quite logical to question:
why there is a "remove this" only command and there is instead an "add
layer" and an "add group" seaprated.
Why two "add" and "one" remove ?
So the next logical question is why not remove the two add ad introduce
only an unique "add here" in the context-menu ?
So my response was to a path that can start with the remove button and
logically end on the "add button".
Regards,
Andrea.
Il 06/09/2014 08:12, Mathieu Pellerin ha scritto:
> I don't think you should comparing adding group/dataset against
> deleting a group/dataset legend layer. The latter is already unified
> via either a single keyboard shortcut and a single mouse right-click
> -> remove action.
> On 6 Sep 2014 13:04, "aperi2007" <aperi2007 at gmail.com
> <mailto:aperi2007 at gmail.com>> wrote:
> Hi,
> I guess in a GIS oriented product
> Is necessary to avoid to mix the interface characteristics (the
> group is an interface object) and the data characteristics (the
> shapefile is not an interface object).
> I guess more beter if add/remove dataset is separated phisically
> from add/remove a group.
> The dataset is a phicical think. The shapefile is using separately
> from the qgis project.
> The group is not separately from qgis project.
> I guess is good question to have a "remove group" but avoiding to
> have a only button "ADD Everything" or an only button "Remove
> everything"
> Also I guess is important to help to understand when we are on
> dataset (physical) and when we are on interface (logical).
> Regards,
> A.
> Il 06/09/2014 07:10, Mathieu Pellerin ha scritto:
>> Greetings,
>> I'd like to circulate a UX proposal and see how people react.
>> For a very long time, QGIS' Layers toolbar has featured a "Remove
>> layer(s)" button. I have seen two issues with the button:
>> - Its placement becomes really odd when plugins add button(s) to
>> the Layers toolbar (for e.g. the New Memory Layer plugin as
>> pictured here [ http://imgur.com/CEcIC3K,QvUzrti ])
>> - It can only remove vector/raster layers, won't remove groups
>> With the recent improvements done by Martin Dobias on the legend,
>> and in particular with his addition of a layer panel embedded
>> toolbar, I propose that:
>> - The "Remove layer(s)" button be moved to the layer panel
>> embedded toolbar [ http://imgur.com/CEcIC3K,QvUzrti#1 ]
>> - The button functionally is improved so it can also deal with
>> the removal of group(s)
>> Alternatively, we could get rid of the button altogether since
>> layers and groups can be removed via right click or keyboard
>> shortcut, but I suspect the touch screen based users might object.
>> Any objection to moving the button to the new layers toolbar?
>> Math
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140906/13e2f31b/attachment.html>
