[Qgis-developer] lwgeom processing provider wainting for processign refactoring
Victor Olaya volayaf at gmail.com
Sat Sep 6 02:23:59 PDT 2014
The refactoring is done, but i think Luigi is talking about the changes to
keep backwards compatibility. I tried the import redirections that Nathan
suggested, but they do not seem to fix the issue and there is still a need
to adapt plugins to the API change.
Ideas are welcome. Otherwise, you can safely adapt your plugin code and, as
Alex said, we will try not to change the API again unless there is a major
need for that.
Cheers
2014-09-05 17:41 GMT+02:00 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi Luigi,
> AFAIK refactoring of parameters/outputs completed.
> And we will try to avoid API breaks in future
> 2014-09-05 14:12 GMT+03:00 Luigi Pirelli <luipir at gmail.com>:
> > Hi,
> > current lwgeom processing provider doesn't work with processing in
> > master version due to Processing refactoring.
> > Modification are trivial in this moment, but I don't know when this
> > refactoring will end to fix definitive patches to the provider.
> > Victor can you let me/us know refactoring roudmap?
> > Thank you  Luigi Pirelli (luigi.pirelli at faunalia.it - luipir at gmail.com)
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140906/c7a669ef/attachment-0001.html>
