[Qgis-developer] Adding modules in Processing
Victor Olaya volayaf at gmail.com
Sat Sep 6 13:27:44 PDT 2014
One thing worth mentioning is that Processing does not figure out the
version of SAGA that you have installed. The default one (the one packed
for instance in the standalone installers) is 2.0.8. The user has to
manually specify the version he is using, between 2.0.8 and 2.1.0
There is no mechanism right now to deal with a 2.1.2 algorithm, so it is
only displayed in the toolbox if the user has SAGA 2.1.2 installed instead
of an older version, so maybe we should work on that as well, and not just
adding new algorihtm descriptions (though that is needed as well, of course)
Cheers
2014-09-06 22:15 GMT+02:00 Victor Olaya <volayaf at gmail.com>:
> You just have to add a new text file to
> the processing\algs\saga\description folder
> The syntax of the file is the same used for GRASS algorithms, which is
> described here
> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/algs/grass/grass.txt
> Hope this helps
> 2014-09-06 21:40 GMT+02:00 skampus <skampus at gmail.com>:
>> hi, i've searched for info about this topic, but i didn't find anything.
>> so please, is there anyone who can explain how adding some existing
>> modules
>> in saga 2.1.2 into processing?
>> infact, in this last version of saga there are some very useful modules,
>> in
>> my opinion, that could be available via Processing
>> thank you in advance
>> s.
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Adding-modules-in-Processing-tp5160553.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140906/8ec95647/attachment.html>
