[Qgis-developer] Getting center of layer in lat/long
Mark Coletti mcoletti at gmail.com
Mon Sep 8 14:36:55 PDT 2014
Ok, I figured it out on my own.  Here're the code snippets for computing
the center of a layer in geographic coordinates, and then doing the same
for the current viewport.
First by layer:
        layerCenter = layer.extent().center()
        if layer.crs().geographicFlag() : # if already lat/long, do nothing
            return layerCenter
        else :
            sourceCRC = layer.crs() # get the coordinate reference system
being used
            # 4326 is WGS 84
            coordinateTransform = QgsCoordinateTransform(sourceCRC.toWkt(),
QgsCoordinateReferenceSystem(4326).toWkt())
            return coordinateTransform.transform(layerCenter)
And now the center of the viewport in geographic coordinates:
        layerCenter = mapCanvas.extent().center()
        if mapCanvas.mapSettings().hasCrsTransformEnabled() : # if
projected, do inverse projection to geographic coordinates
            sourceCRC = mapCanvas.mapSettings().destinationCrs() # get the
coordinate reference system being used
            # 4326 is WGS 84
            inverseLayerCenter = coordinateTransform.transform(layerCenter)
            return inverseLayerCenter
        else :
            return layerCenter
Do you think these would make for good additions to the "Code Snippets"
section
<http://docs.qgis.org/2.2/en/docs/pyqgis_developer_cookbook/snippets.html>
for the online documentation?
Cheers,
Mark
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140908/6447eee1/attachment.html>
