[Qgis-developer] Crash of QGIS 2.4 built on RHEL 6 with Qt 5.3
Dave Johansen
davejohansen at gmail.com
Tue Sep 9 08:03:13 PDT 2014
Ya, my hope is to get everything packed up and included in EPEL. It will
probably be a little bit until I get that all setup because there are a few
dependencies that need to be packaged as well, but hopefully it won't be
too long.
Dave
On Tue, Sep 9, 2014 at 12:00 AM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Good job.
> Can we hope for rpm files for these? Would be nice to offer them
> officially.
> Matthias
> On Die 09 Sep 2014 00:34:36 CEST, Dave Johansen wrote:
> > Yep, QWT and QWT-Polar were the offending libraries. Once I built a
> > Qt5 version and used this, QGIS 2.4 loaded up just fine on RHEL 6.
> > Thanks for the help,
> > Dave
> > On Mon, Sep 8, 2014 at 3:52 AM, Matthias Kuhn <matthias.kuhn at gmx.ch
> > <mailto:matthias.kuhn at gmx.ch>> wrote:
> > Hi Dave,
> > Maybe it could be QWT (and QWT-Polar) which are linked against
> > Qt4? You will probably have to recompile such dependencies as well.
> > On Fri 05 Sep 2014 08:24:33 PM CEST, Dave Johansen wrote:
> > On Thu, Sep 4, 2014 at 11:38 PM, Matthias Kuhn
> > <matthias.kuhn at gmx.ch <mailto:matthias.kuhn at gmx.ch>
> > <mailto:matthias.kuhn at gmx.ch <mailto:matthias.kuhn at gmx.ch>>>
> > wrote:
> > Hi Dave
> > there is still Qt 4 involved (partially?) as the 4 in the
> > end of
> > this line indicates:
> > #10 0x00007ffff3e24ce6 in __do_global_ctors_aux () from
> > /usr/lib64/libQtCore.so.4
> > Did you clean the build directory after the build attempts
> > for master?
> > I just did a complete clean build just to be sure and it had
> > the same
> > crash. The same crash happened. Here's the output from ldd
> > grepped for qt:
> > libQt5Sql.so.5 => /usr/lib64/libQt5Sql.so.5
> > (0x000000357c400000)
> > libQt5WebKit.so.5 => /usr/lib64/libQt5WebKit.so.5
> > (0x0000003585200000)
> > libQt5WebKitWidgets.so.5 =>
> > /usr/lib64/__libQt5WebKitWidgets.so.5
> > (0x0000003580000000)
> > libqgis_core.so.2.4.0 =>
> /home/dlj/projects/qgis-qt5/__build/../install/lib/libqgis___core.so.2.4.0
> > (0x00007faf1211c000)
> > libqgis_gui.so.2.4.0 =>
> /home/dlj/projects/qgis-qt5/__build/../install/lib/libqgis___gui.so.2.4.0
> > (0x00007faf11a01000)
> > libqgis_analysis.so.2.4.0 =>
> /home/dlj/projects/qgis-qt5/__build/../install/lib/libqgis___analysis.so.2.4.0
> > (0x00007faf11772000)
> > libQt5Quick.so.5 => /usr/lib64/libQt5Quick.so.5
> > (0x000000357c800000)
> > libQt5Qml.so.5 => /usr/lib64/libQt5Qml.so.5
> > (0x000000357b200000)
> > libQt5OpenGL.so.5 => /usr/lib64/libQt5OpenGL.so.5
> > (0x000000357f400000)
> > libQt5Sensors.so.5 => /usr/lib64/libQt5Sensors.so.5
> > (0x000000357fc00000)
> > libQt5Network.so.5 => /usr/lib64/libQt5Network.so.5
> > (0x0000003579e00000)
> > libQt5PrintSupport.so.5 =>
> > /usr/lib64/libQt5PrintSupport.__so.5
> > (0x000000357ee00000)
> > libQt5Positioning.so.5 => /usr/lib64/libQt5Positioning.__so.5
> > (0x000000357f800000)
> > libQt5Xml.so.5 => /usr/lib64/libQt5Xml.so.5
> > (0x000000357a200000)
> > libQt5Concurrent.so.5 => /usr/lib64/libQt5Concurrent.__so.5
> > (0x00007faf1133c000)
> > libQt5Svg.so.5 => /usr/lib64/libQt5Svg.so.5
> > (0x00007faf110eb000)
> > libQt5Widgets.so.5 => /usr/lib64/libQt5Widgets.so.5
> > (0x000000357ba00000)
> > libQt5Gui.so.5 => /usr/lib64/libQt5Gui.so.5
> > (0x000000357aa00000)
> > libQt5Core.so.5 => /usr/lib64/libQt5Core.so.5
> > (0x0000003578a00000)
> > libQtSvg.so.4 => /usr/lib64/libQtSvg.so.4
> (0x0000003582200000)
> > libQtGui.so.4 => /usr/lib64/libQtGui.so.4
> (0x00007faf0fda5000)
> > libQtCore.so.4 => /usr/lib64/libQtCore.so.4
> > (0x00007faf0f941000)
> > So it looks like you already pointed out that the Qt4
> > libraries are
> > being linked in as well for some reason. Any ideas on what I
> > should do
> > to run down where this issue is coming from?
> > For your other question (lrelease-qt5) you can revert this
> > commit:
> > 9c6f1698fcb3df758f024fad99ed65____06d6a38e0d
> > I guess I'll have to figure out another approach to handle
> > this
> > suffix than just deleting it like this commit does.
> > I reverted that commit and it built without me specifying the
> > path to
> > lrelease-qt5.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140909/7638deec/attachment.html>
