[Qgis-developer] Allow experimental plugins
Rémi Bovard remi.bovard at gmail.com
Thu Sep 11 06:37:15 PDT 2014
Hi Denis,
Thanks for your answer but this is not better...
If I manually enable / disable the checkbox, I can see both result with:
s.value("Qgis/plugin-installer/allowExperimental")
s.value("/qgis/plugin-installer/allowExperimental")
Do you know if there is something else to do to allow experimental plugins?
Thanks.
Rémi
2014-09-11 15:28 GMT+02:00 Denis Rouzaud <denis.rouzaud at gmail.com>:
>  Hi Rémi,
> On 11.09.2014 14:39, Rémi Bovard wrote:
> Hi list,
>  I'm trying to allow experimental plugins via a Python script and it
> doesn't work.
>  Here is the code:
>  from PyQt4.QtCore import QSettings
> s = QSettings()
> s.setValue("Qgis/plugin-installer/allowExperimental", True)
> not sure, but try lowercase + first slash:
> s.setValue("/qgis/plugin-installer/allowExperimental", True)
> is this better?
>  What am I doing wrong?
>  Thanks in advance.
>  Rémi
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140911/d38d6219/attachment.html>
