[Qgis-developer] Problem with Qgis c++ plugin
Nejia
nejia at spaceyes.fr
Wed Sep 17 09:20:40 PDT 2014
Any one could give me the build options used to compile the released version
of Qgis 2.4 please ?
De : qgis-developer-bounces at lists.osgeo.org
[mailto:qgis-developer-bounces at lists.osgeo.org] De la part de Nejia
Envoyé : mercredi 17 septembre 2014 14:12
À : qgis-developer at lists.osgeo.org
Objet : [Qgis-developer] Problem with Qgis c++ plugin
I have a Qgis C++ plugin that adds a tool, I build my plugin using the
libraries of Qgis built from sources
<https://github.com/qgis/QGIS/tree/release-2_4> with Microsoft Visual
Studio as described here
<http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/I
NSTALL.html#toc14> .
My tool works fine with built Qgis but not with the installed Qgis 2.4.
When I activate my tool and then turn to another tool Qgis crash and write a
minimum dump file:
Dump File: qgis-20140915-111427-2760-1564-8fdd08a.dmp :
C:\Users\Admin\AppData\Local\Temp\qgis-20140915-111427-2760-1564-8fdd08a.dmp
Last Write Time: 15/09/2014 11:14:28 Process Name: qgis-bin.exe : C:\Program
Files (x86)\QGIS Chugiak\bin\qgis-bin.exe Process Architecture: x86
Exception Code: 0xC0000005 Exception Information: The thread tried to read
from or write to a virtual address for which it does not have the
appropriate access. Heap Information: Not Present
For more details see the attached files
Best regards
Nejia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140917/4a5ab67b/attachment.html>
