[Qgis-developer] Processing causes major slowness at QGIS startup
Luca Manganelli
luca76 at gmail.com
Fri Sep 19 05:02:56 PDT 2014
On Thu, Aug 28, 2014 at 5:31 PM, Victor Olaya <volayaf at gmail.com> wrote:
> I am away until Sept 5th, but will work on that once i am back. Didn't know
> about the init() and initGUI() separation, so thanks for the info.
> A large part of the time it takes to start Processing is probably spent in
> reading the description files for SAGA, GRASS and OTB algorithms, so i will
> try to find a way of making that faster, or avoiding it if not needed at
> first
Hi Victor, have you found the cause problem? It would be nice if you
can fix fix this startup slowdown before 2.6 version (dated at end of
octoer).
Thank you!
Luca
