[Qgis-developer] QGIS with up to date package versions
Jürgen E. Fischer jef at norbit.de
Mon Sep 22 01:23:15 PDT 2014
Hi Matthias,
On Mon, 22. Sep 2014 at 10:06:17 +0200, Matthias Ludwig wrote:
> Hi, has someone a ready to use version of QGIS (Windows) with more up to date
> packages? Or a windows specific description on how to build one?  The used
> versions are very old. For the moment I try to use this description, but
> compiling on Windows is....yes....far from being comfortable...
> http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html
Which packages are you referring to?   And where did you find that ancient
link?   The current packages are available on our website[1].  You can also
find a link to the sources and INSTALL[2] there, that has a more current
description on how to build.
Jürgen
[1] http://www.qgis.org/site/forusers/download.html
[2] http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140922/f6ef1642/attachment.pgp>
