[Qgis-developer] QGIS sometimes freezes in Windows 7 x64
Casper Børgesen (CABO) CABO at NIRAS.DK
Mon Sep 22 01:46:31 PDT 2014
Hi Andreas.
It might solve the problem, but as long as I cannot reproduce the problem, disabling multi threaded rendering only saves me the trouble of the issue (in case it helps at all). I would rather see if I can help narrow down the problem by not disabling and give you all the information I can.
But thanks for the tip. I will relay it to my colleagues.
Regards, Casper
-----Original Message-----
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: 22. september 2014 10:33
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] QGIS sometimes freezes in Windows 7 x64
Hi Casper,
Did you try disabling parallel rendering to make sure that the crashes/freezes are really related to the multi-threaded renderer?
Settings -> Options -> Rendering -> Disable Checkbox "Render layers in parallel using many CPU cores"
There seem to be issues with the multi-threaded renderer, but apparently they are very difficult to reproduce and debug.
Fortunately one can very easily disable multi-threade rendering until the issues are solved.
Andreas
Am 22.09.2014 08:24, schrieb Casper Børgesen (CABO):
> Hi Bernhard.
> I cannot reproduce my issue and it doesn't seem related to loading.
> My project consists of:
> - No raster
> - Shapefiles only
> - Rule based styling
> - No groups
> Though our setups are very different, the issues could be related. If I could reproduce the issue, it would be a lot easier to report it.
> I can see the see the yellow balloon tip informing me of messages added to the message window just before QGIS stops responding. But I can't see the messages since QGIS is not responding.
> Regards Casper
> [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Bernhard
> Ströbl
> Sent: 22. september 2014 10:09
> Hi Casper,
> please check if your problem is related with this [1] issue and if yes report any additional infromation there.
> [1] http://hub.qgis.org/issues/11141
> Bernhard
> Am 22.09.2014 09:55, schrieb Casper Børgesen (CABO):
>> Too often QGIS 2.5 weekly (it happens in 2.4 too) tends to freeze
>> while drawing the layers. It normally happens when I move around or
>> zoom out, but I think it can happen when displaying a layer after
>> loading it). So I guess it has something to do with drawing data or
>> accessing data from the source.
>> I would like to report this issue (or these issues), but I am not
>> ready to begin debugging QGIS yet.
>> How can I best help you devs in investigating the issue?
>> -Is there a log file I can gain anything from?
>> -I don't get any messages about a minidump.
>> -QGIS is not responding, so I can't access the message log.
>> -Normally QGIS doesn't return to a working/responding state.
>> My OS is Windows 7 x64 and QGIS is 2.5.0-37 weekly (e46aa62).
>> Regards Casper
>> __________ Information from ESET Mail Security, version of virus
>> signature database 10446 (20140921) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://www.eset.com
