[Qgis-developer] Problem with Qgis c++ plugin
Hartmut Tschauner hartmut.tschauner at gmail.com
Mon Sep 22 08:11:46 PDT 2014
Thanks for your response, Jürgen.
Yes, I did build my plugin with the release libraries and that results in
an access violation every time I switch from my own to a built-in map tool.
This does not happen if I build plugin and QGIS in one go and run my plugin
as in that QGIS I built myself.
On Fri, Sep 19, 2014 at 6:27 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Hartmut,
> On Thu, 18. Sep 2014 at 01:10:50 -0700, tschaun wrote:
> > I have the same problem, and have had it for some time. I previously
> reported
> > it for 2.2. My previous post received a response from Jürgen who said he
> had
> > never seen this problem. This is not surprising as core developers build
> the
> > application and plugins in one go, whereas this problem only crops up
> when a
> > C++ plugin is deployed into a QGIS installation other than the one it was
> > built with.
> Did you build you plugin with the libraries shipped with QGIS (ie. in the
> OSGeo4W qgis-dev package for master or qgis-devel for the released
> version)?
> That's what I do.   I don't build external (ie. non-core) plugins and qgis
> in
> one go either.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> iQIVAwUBVBxneBBsJ9SQbsVUAQKQDQ/8CuynOmVLlt892/EqT4z4+w/AqSEZXEWr
> ictK61Agcf670FknRtdQj9dqdKX3YIvP6VLettSbAP2JlItoq+nbaXnwmUD/zmap
> rspLYoXhNJI3D1Ph2SKWnONLRxIakdlYF7DKm3PMA//0y4tOAfFAnwPF4rNCFC2M
> drhGrTnAmaXeBGz5ZWwDFhoo4UXkUN8vTrpAi8iUdd37OV3EWGyeEO78IrrcglnQ
> tXD/GFMx2TfHIm59FdMXSp6zKgbyXUpmyRHK9H5a8K3tuIXQSU1Ime0GRuuRHB38
> yQK8oBACnVHefStEEsBP4MyUzYJH+eOrU5tRVvZlxiVnAKov0tNhfYos4Xd5Gl6K
> v/EROt1oEHUvPVSKfTq6GgvQqp9hCHb4k7/STBNUaDJStbWhwUeXHd+d7SHskhHZ
> 6ePXdKNyOXYUPtRzjiGZNT496t7CerePgTPMYdWewSKLZUHNkB0Pw9x24+BeRfrd
> IMShLhCMRsT9hyYUHyhN5JiXOiIKee5XVIwVNNrjdC0WrEzb85G+5iojFZJ19EbD
> beePLavdCBnV+iQEhbhZoi0EwWb32HysLy56FmulZtSS4pkmOr4hoWwMbVrZP6ns
> FxV72XFG7NIXFC36FP2cHCjDDYCPsbDP8wUKPs2S0dPs5RteHMKP4pt0965n/mOL
> xX0O2gXHkUs=
> =JSji
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
Hartmut Tschauner
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140922/55726151/attachment-0001.html>
