[Qgis-developer] standardisation of the editing map tools: modify behaviour of press-pan-release tools
Ramon Andiñach
custard at westnet.com.au
Wed Sep 24 18:01:18 PDT 2014
On 25 Sep 2014, at 6:01, Ramon Andiñach <custard at westnet.com.au> wrote:
>> I am not saying the idea is bad but the consequences might be larger than you expect especially for occasional users if the behaviour of the tools is different from what they would expect from their prior experience (of other GIS or graphic software).
> I'll fire up MI today and have a look.
Mapinfo results
* edit node tool
Moving nodes
- select feature
- select reshape tool
- click in node and drag
Adding
- select feature
- select add node tool
- click to add point
* move feature
- click on feature and drag
* rotate feature
- select feature
- click on rotate point and drag
* move label
- click on label and drag
* rotate label
- select label
-ramon.
