[Qgis-developer] standardisation of the editing map tools: modify behaviour of press-pan-release tools
Denis Rouzaud denis.rouzaud at gmail.com
Wed Sep 24 23:27:39 PDT 2014
On 25.09.2014 08:02, Nathan Woodrow wrote:
> Hey Denis,
> There is a 4th option of course and that is a key modifier for
> override to do click-click.  I was planning on doing that a while ago
> when I thought about the same thing.
> So adding something like shift+click to enabled click-click mode.
> Not sure if that is better but there is not a good way to change this
> kind of thing.
> - Nathan
Or we use the modifier for the drag'n'drop, if people like to keep a
button mouse pressed, they don't mind using one more key... just joking!
Modifiers are a pain when you use the tools a lot.
Anyway, if we do this, this can be combined with the options (solution 3)
Standard mode: simple click: drag'ndrop, shift: click-click
CAD mode: simple click: click-clcik, shift: drag'n'drop
> On Thu, Sep 25, 2014 at 3:46 PM, Denis Rouzaud
> <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> wrote:
>     Hi all,
>     I'll try to summarize.
>     *QEP*: I don't mind doing one, but I think it's a bit early since
>     we are still discussing.
>     *Problematic*: Drag'n'drop map tools prevent from enhancing CAD
>     tools in QGIS. For this, it is *required *to add click-click to
>     all map tools.
>     *Other softwares:*
>     CAD softwares use click-click actions while design and GIS
>     (Mapinfo, what about ESRI?) use drag'n'drop.
>     New users or even current users might be afraid of such a change.
>     *Pros of methods:*
>     Advantages of click-clik:
>     * allow other actions to be done in the movement
>     * allow cancelling the action (this was not pointed out yet)
>     Advantages of drag'n'drop
>     * More intuitive (for non-CAD users, which I believe is the majority)
>     I see *3 (and a half) solutions* (thanks to Matthias for pointing
>     some):
>     1.*Replace current* drag'n'drop to click-click
>     + simplest solution to maintain
>     - need time for new users to get used to this
>     2.*Enable both* click-clik and drag'n'drop: a short click will
>     free the node/feature while a long click (*) will allow drag'n'drop.
>     + both solutions are here
>     - might be confusing for a "standard" user to make a short click
>     and have a node moving without knowing what to do (although escape
>     would cancel the thing)
>     3. Provide both behaviours and *choose which one to use in
>     options* (e.g. enable CAD behaviour for map tools).
>     - behaviour not coherent along the different installations
>     half solution: click-click in map tools, allow drag'n'drop in the
>     main identify tool. Like *Microstation*.
>     - this works only for move features (i.e. not feasible for rotate
>     and node tools)
>     Please comment these solutions, to see if there's a consensus.
>     I'll start and vote for 1. ;)
>     Cheers,
>     Denis
>     * The determination of what should be done is made on the distance
>     in pixels from the press position to the release position. If it's
>     small it is considered as a short. Time might also get into
>     consideration: if you long-click but don't move it could be
>     considered as cancel.
>     On 24.09.2014 10:56, Denis Rouzaud wrote:
>>     Hi all,
>>     There is somehow an inconsistency in the behaviour of the current
>>     editing map tools.
>>     Some, like add features, uses the left click to trigger the action.
>>     Others, like the node tool or move feature use press-pan-release
>>     mouse events:
>>     * mouse press to select the node/feature
>>     * mouse mouse to move it
>>     * mouse release sets the position.
>>     I would propose to standardise this and for the latter tools
>>     propose the following work flow:
>>     * left click enables the move
>>     * left click again to validate at position
>>     * or right click to cancel
>>     Why changing this?
>>     If you look at CAD software, they also use the proposed approach.
>>     And there's a reason for doing so, which is valid for QGIS too.
>>     We are looking at improving the CAD tools in QGIS. In this area,
>>     I recommend trying the fantastic CADinput plugin made by Olivier
>>     Dalang. The plugin works on top of any map tool and enables CAD
>>     tools for each of them.
>>     The problem with the press-pan-release map tools is that you
>>     can't truly interact while you are actually in the action of the
>>     map tool (holding the click):
>>     * you can't click anymore and this prevents from using
>>     intermediate points (you have to use the tool several times and
>>     repeat the operation as many times as intermediate points you need)
>>     * it is not really user friendly to have to press keys while
>>     holing the click
>>     This is why, changing the map tools behaviour is requested if we
>>     want to go further with CAD tools in QGIS.
>>     Regarding the future of CAD tools in QGIS, I am quite sure the
>>     plugin proposed by Olivier would be a good way to go for QGIS,
>>     but it still might be a bit early to integrate it in core. The
>>     idea is rather first to extend the API and propose ready to use
>>     methods, so it will be easy to implement your preferred solution
>>     in a plugin.
>>     But first, we need to standardise the map tools.
>>     So, the bottom line, any objection to changing the behaviour of:
>>     * edit node tool
>>     * move feature
>>     * rotate feature
>>     * move label
>>     * rotate label
>>     * any other press-pan-release map tool that I am not aware of
>>     Best wishes,
>>     Denis
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140925/128996d2/attachment-0001.html>
