[Qgis-developer] [FEATURE][QGIS-Server] Legend filtering based on map in GetPrint Request
René-Luc Dhont
rldhont at gmail.com
Fri Sep 26 03:20:59 PDT 2014
Hi devs,
Code freeze starts today and I have a new feature for QGIS-Server to be
reviewed.
I opened a pull-request and assigned it to @mhugent but if someone else
like @wonder-sk can validate it, I'll merge it.
This pull-request has be made for Legend filtering based on map in
GetPrint Request
The legend in composition was fixed and did not represent the layers in
the map.
With the work made by @wonder-sk <https://github.com/wonder-sk> on
layer-tree and QgsComposerLegend users will be able
to configure composer legend as based on all the project layer tree with
auto-update
model or filtered by map.
This commit reused these two QgsComposerLegend's properties to filter it
based on map in
GetPrint Request
The issue #4003 qgis_mapserver getPrint legend options can be closed.
Regards,
René-Luc D'Hont
3Liz
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140926/1abbf6b0/attachment.html>
