[Qgis-developer] Memory Layers - some proposals
alain al.bertho at free.fr
Sat Sep 27 01:57:01 PDT 2014
Hi all,
Le 25/09/2014 11:10, Matthias Kuhn a écrit :
> Aren't there two different possibilities in which such layers can be
> used:
>  * As a scratch layer for the user, which he may want to save in the end
>  * As a means for plugins to show information to the user
One of the main reason memory layers are used by plugins is that you
can't write a python provider. If you want to handle a proprietary
format or a weird format, you read the file and fill a memory layer.
This is the difference between memory layers and others: no provider,
data is manually pasted or created by plugin. If saving is required for
project consistency, maybe this could be done through geojson (or other)
provider. One attribute in the qgs project would indicate that it is a
memory layer, and that's keep quite simple and transparent.
Alain
